Hi, the problem I have run into with my RCA L32HD35D is that after about 30 minutes of watching a program I will lose picture on the screen. The sound is audible but I have to turn off the TV and than turn it back on to which the process will repeat. This to me sounds like a prolem in the power supply, but it could be elsewhere. Help greatly appreciated
  • 12,061 Answers
Http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
http://elektrotanya.com/?q=TVs&page=24
Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Posted on May 02, 2010
Pictures blinks on and off and no sound
Sounds like it should be under warranty so call a xervice center and ask.
Sep 12, 2014 | RCA L32hd35d 32 in. Flat Screen LCD...
Why does the picture keep blinking?
If there is any loose electrical contacts, this might happen.
May 20, 2013 | RCA L32hd35d 32 in. Flat Screen LCD...
Sound no picture
Picture on about 30 sec.,just dies have sound left only?This problems the 2 long LCD inverter boards are dead.The 2 long LCD inverter boards,help the LCD screen to have a backlight to produced a picture.Tries Websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes inverter boards for the replacement.
Jun 24, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
Our RCA 32 inch TV L32HD35D has sound but the picture has a pulsating white screen---no picture. We have only had the TV since approximately May 2009. Is there a way to fix the problem? Thank you Susan J....
No,Ur tv under a year old?Still under warrenty?Call RCA for warrenty repair.This problems is a major problems for the tv.The Tuner board it dead,must be replaced it cost u at lest $200 for a refurbish Tuner board.And u have to do the labors ur self.
Apr 25, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
Problem for RCA L32HD35D 31.5 inch HDTV LCD TV I turn it on and no piture just sound
With a bright flashlight see if you can see a picture.. If you can this indicates your invertor board has failed. If not more than likely your main video board has failed. Ebay has tons of parts for these tv's.
Mar 20, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
RCA 50" Projection TV
When you have picture, look a the back of the TV and see where light is eminationg from through grill or vent of some sort. When you lose the picture, see if you still have light. If you do, then you don't have a ballast problem you have some sort of Light Engine problem and that will be an expensive fix, but not as expensive as if you have to replace the ballast that drives the back light.
Sep 21, 2009 | RCA L50000 50" Rear Projection Television
Losing picture on tv!
The ITC008 chassis is commonly riddled with poor solder connections. Good soldering station, patience and some good light and magnification and you might be able to fix it... Or you could spend a few dollars and run it into the shop and have a tech do it! It's not an expensive repair.
Bill
Apr 10, 2008 | RCA 32V550T 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
