Question about eMachines T3646 Refurbished AMD Desktop Computer - AMD Sempron LE-1250 2.2GHz, 1GB DDR2, 160GB SATA
Im using a emachines T3646 computer,only pwrled and 1syst fan wrk
Im using an emachines T3646 computer,and just installed my Psu and Cpu,When i go to boot up,only thing that turn's on is one of my system fan's,amd my power led light.Did i do something wrong?Need help trying to boot this thing up!?
  • 981 Answers
Yes. Got RAM? The heatsink fan? How about a video card, and all the 12V (4 to 6 pin) connectors? All plugged in suitably?
Posted on May 02, 2010
Hannstar ACER j mv-4 doesn't start up
no pc stated, maker or model #,, sounds kinda DESKTOP>?????
no oS stated
step one is test the MV4 on a known working pc,!!!
why wait, this so basic....
are you using VGA to VGA or DVI to DVI connections??????
the DESKTOP,
no sound means the fans are dead and PSU dead.
The PSU will run for 1 second and fans run now. if not PSU is dead.
if fans do run and stop that means PSU dead or mobo shorts or bad reg on MOBO. or bad ram. strip it down to test that.
ok fan runs that means 12vdc good. if stay running,
and if PSU stays up, then NEXT TEST IS Screen
is it 100 % dead, or do you get text or logos."
100% dead means to me bad VGA card(or chip GPU)
if the Hot key for BIOS fails, that means bad POWER/
or bad VIDEO card.
the fans run but are silent, I envy you.. sell me your fans....
im 1/2 deaf from Vietnam and can still hear all my fans.
my DT has 4 fans min. (it's Alien-ware box++++)
CPU, GPU and PSU, and 1 case fan,all must work.
do yours?
when you power on a PSU, the fans run and stay running
if that takes sides off so be it, ever clean the 5lbs of lent seen inside from 5 years, collected?
If you dont service any pc, this packs up and the CPU overheats
and shuts its self down by DESIGN.
why no do that service first.
see that CPU, see those fins, see that pack up there.
blow it out, outdoors, using CAN-0-AIR
mine over heats my GPU fast with lent, my Graphics car runs super hot and fast and lent is NOT ALLOWED here. ever..
old pcs with slow cpu ,, tend to packup slower, well lets say
they can run longer with huge lent here. its just slug processor so...
that is what it does.
recap.
  1. fans all run.
  2. BIOS dead?
  3. screen dead. no words no text at all.
  4. MV4 tested on other PC works. proves PC bad.
  5. LENT PACK job. as all do every year here, all.
  6. Bad VGA caRD. or using wrong port if PC has 2 VGA jacks. !
Jun 22, 2017 | Compaq Computers & Internet
Computer won't boot - fan on cpu does not run - cd drive does not power up -
Hi.
If there is no sign of life, then it is usually a power supply problem. Check PSU connector. If PSU fan does not turn on check the power cable. If power cable is good, test power from PSU using a multimeter and eventually replace PSU.
Dec 03, 2010 | E-Machines eMachines Refurbished EMA...
I have a emachine el1200 desktop and the power led light is staying on but I have no power to the fans or anything. The computer will not come on at all and the blue light stays on. I tried unplugging it...
hi gregrobinhol,
check if the psu fan is working if not then the psu is the problem if the cpu' fan is not working unseat all the memory, clean the metal contacts underside of the memory with an alcohol and a cotton let it dry for 5-10 mins then put it right back. if this does not work you have a defective motherboard.
hope this helps
thx
banaple
Sep 02, 2010 | E-Machines eMachines Desktop PC
Can emachine t3646 be down graded to windows xp
yes of course it able to use theh latest version so it is also capable of using sindows XP...since it both a microsoft product....
format your unit and install a fresh copy of windows xp...
Oct 19, 2009 | eMachines T3646 Refurbished AMD Desktop...
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
No power
ok dandan, please tell me you live in nj. I am having the same problem with my puter and did every step you did what is up with this??
Jun 12, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
EMachine T3642 Downgrading
Here is the eMachines page with all the driver downloads for the motherboard in your machine.
Apr 08, 2009 | eMachines T3646 Refurbished AMD Desktop...
Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
eMachines T3646 Refurbished AMD Desktop Computer - AMD Sempron LE-1250 2.2GHz, 1GB DDR2, 160GB SATA  Logo
207 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
