Question about Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator
I`v got an american whirlpool fridge/,somehow the freezer door was left open (not sure for how long),but when discovered lights inside were flashing/clicking.the water dispenser/temperate control on the front has no lights lit and doesn`t seem to have any power.if i turn the power off then back on the lights stop flashing/clicking inside,until i open the freezer ?help please
    Genius:
  • 1,044 Answers
A serious problem You have to take assistance from a technician. Due to overload as the door was left opened either the compressor motor or the condenser is burnt out. Please have it checked up. You will not be able to repair it yourself as it may require replacing parts.
Posted on May 02, 2010
Our Whirlpool 26' Frch Dr purchased 2 years ago - freezer door is on the bottom- sensor is going off indicating door is open- however the door is closed- HELP !!
Make sure the door is closing straight. Open the upper doors and look to see if the seal is flush with the body of the fridge. If it is see if the light switch in the freezer is operating properly by pushing it. If the light goes out it is. If the light stays on the switch is shorted inside.
Dec 02, 2016 | Whirlpool Refrigerators
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Feb 26, 2018 | Whirlpool ET1FTTXK Top Freezer...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Door difficult to open
Simple fix! A small puddle of water near the fridge led me (indirectly) to this fix. Our model is a fridge only, no ice or water dispenser and nothing spilled inside. Upon closer inspection I found a narrow tray along the back wall above the crisper drawers with a drain hose leading under the unit. Apparently it's a condensate drain, a plugged one at that! I cleaned it out, yuk, and soon discovered it serves a dual purpose... as a vent to help relieve the pressure from the vacuum created immediately after closing the door. It has renewed our love affair with this fridge. Hoo Hoo!
Jul 14, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator Logo
202 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
