Question about Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel
Shower fell apart or actually blew off under water pressure
I have tried to put it back together again but some of the soft plastic toungues are broken.
We have two same shower heads in the house and 2 weeks later the other one blew apart and we had not tampered with it. I cant get this back together either. The water pressure keeps blowing the "holed part and slide ring off. The funny thing is that the second one is rarely used and although a bit of grunge inside not substantial
  • 349 Answers
Check water pressure valve if you are on city water it may be bad and allowing water to be more than it can take.
If this is the case you can make you up a gauge on a water hose connection to hook up to and outside faucet to get a pressure reading.
Posted on May 03, 2010
How do I get the pulse function to work after cleaning the shower head (fixed)
I am not familiar with this faucet, but in the future, don't disassemble it. Just take the head off and soak in a mixture of warm water and vinegar for a couple of hours and take a toothbrush to it.
Jul 13, 2014 | Grohe Home
Craftsman drill model 315
If it just fell apart the do not waste your time putting it back together as it will only fall apart again when you are working. Just get a new chuck.
Jun 28, 2013 | Drills
I replaced the seats and springs in my delta single handle faucet put it all back together and now I have nothing. I took it apart again - actually several times and put it back together with the same
messy ,, but while u had it apart did u turn on the water to see if water would come out at all... we flushed our line and that cleared up the problem.
Jan 19, 2013 | Delta Plumbing
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
My whirlpool fridge is not cold enough, there is water leaking from the top. I leave a plastic bowl under to catch the water. This has to bee emptied every several days. Here is the model ET18PKXGW01. I...
We had the same problem, but the bottom of the fridge was freezing over. Took apart and blew air through the line from under fridge. Goop came out. Put back together and ran perfect!
Jul 31, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
The hot water has no flow . The cold has pressure but when I turn it to hot there is no pressure>
We had the same problem and tore the faucet apart. We found that the white plastic cartridge was not moving. After we pulled the white cartridge out we pulled the interior cartridge out of it (a metal cartridge) and found the inside of it was not moving. We put the end of the allen wrench into the hole of the valve area that allows the water flow and pushed it back out the end. Once we pushed it back together it was like it opened up and broke loose. This faucet was in a bathroom we use infrequently with a jacuzzi tub and we decided to use it again.
Dec 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
My both room has a small water leak
If the two parts screw together you need to get some plumbers tape , turn the water off ,dry the ends and put the tape on tight and just re-screw them back together.
Nov 15, 2009 | American Standard Home
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel Logo
394 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
