Question about Technics SA-EX510
Missing ac plug for receiver
I recently got a used Technics Sa-ex510 receiver and a technics rs-tr272 tape deck. i didn't get an ac wire to "power" my receiver and don't plan on using the tape deck. can i use the ac wire/plug from the tape deck on my receiver?
thanks.
D.
  • 4,234 Answers
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Posted on Mar 25, 2008
SOURCE:
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Power to technics rs-t24 dual deck
I own a RS-T24 as well and stumbled upon this thread while searching for this exact same solution. The RS-T24 generates no power on its own. It gets its power from, in my case, the SU-V75 amplifier. I still have a working SU-V75 and got the following readings out of the plug-in for the RS-T24 on the amp:
Left = pin 1 - (white wire)
Middle = pin 2
Right = pin 3
1-2 = 11.5 vac
1-3 = 23.0 vac
2-3 = 11.5 vac
Jan 30, 2009 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 Dual - Won't Reverse
Cassette decks that have been sitting for long periods have problems with drive belts and idlers becoming slack or decomposing of the rubber compound. If you wish to keep the unit, please have it cleaned and have belts/idlers replaced with new ones by a professional service. Also have controls and switches cleaned of built up tarnish and mildew to prevent noisey or drop-out audio
May 11, 2008 | Technics RS-TR272 Single Cassette Deck
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
487 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
