Question about Kitchen Appliances - Others
LC-SO83R1PG SEALED LEAD ACID BATTERY ; 8 VOLT 3.2 Ah
SOURCE: I have an RCL 300
I just searched the web and found that this website sells them for $16.99.
http://www.dutchovencookbooks.com/products/lanterns/remote.html
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Posted on Apr 21, 2009
SOURCE: I have a VEC127BY with a CB4.5-6 (6V4.5AH/20HR)
loose connection repaired
Posted on Nov 17, 2009
  • 973 Answers
SOURCE: replacement battery for a Vector # VEC137R flashlight
You can order it from Black and Decker, Vector sold all their product lines to them in 2006 and they carry the replacement battery cheaper than anywhere else I found.
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
Posted on May 25, 2010
CarlGlas
  • 283 Answers
SOURCE: I need a replacement for
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Posted on Aug 12, 2010
I need to replace a fifutec sealed lead-acid rechargeable battery [12v -2.8ah]
http://www.atbatt.com carries a large array of sealed lead acid batteries. I did a search for 12V 2.8ah and here is one of the results:
http://www.atbatt.com/sealed-lead-acid-batteries/b/interstate/m/interstate-12v-2-8ah.asp
May 22, 2015 | Camping, Backpacking & Hiking
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
What the differential betwen LC and UB type battery, for example LC-X1220P and UB12220. thanks.
Specs Volt 12 Amps 22 Length 7.13 Width 3 Height 6.57 Terminals NB Weight (17.5) Manufacturer Universal Power Model # UB12220 Universal 12 Volt 22AH Battery UB12220 Universal 12 Volt 22AH Battery
Specs Volt 12 Amps 20 Length 7.126 Width 2.992 Height 6.575 Terminals NB Weight (14.56) Manufacturer Panasonic Model # LC-X1220P Panasonic 12 Volt 20AH BatteryLC-X1220P Panasonic 12 Volt 20AH Battery
Dec 28, 2010 | Panasonic LC-X1220AP - UPS battery - 1 x...
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
I have a Vector 2,000,000 Power Series Spotlight and I need a new battery. The current battery is SEL sealed lead- acid. The number is DMU 3-12 12v 3AH. I have been unable to find this battery...
There is good news and bad news concerning a replacement battery for this particular model light.
The good news is that a suitable, but not exact, replacement will be available at Battery Mart on November 30, 2010.
The bad news is that it cost $29.95.
http://www.batterymart.com/p-sla-1039-12-volt-2-3-ah-sealed-lead-acid-battery.html
I purchased about a dozen of these lights in 2006 and have had them in storage since. No one can or will be more unhappy than I should all of them need new batteries.
Sep 07, 2010 | Vector 2M Pwr Rch Spotlight
Will not charge. Sat for a long period dead.Can the cells be replaced? If so where can they be obtained?
If you can open the box, you should find inside a normal sealed lead-acid battery 12V/60Ah .
If you take its dimensions you can by any equal in size and Ah sealed battery, no matter of producer, but it should be kept charged, and if not used it should be set for charging every month.
Jul 15, 2010 | Xantrex Technology XPower Powerstation...
Volt meter shows 26 volts(2 12 volt in series) but wont run lawn mower. jumped 12 volt car battery and this runs mower at slow speed. is battery dead
Sounds as if battery has internal short. Also have charging system checked. If doing yourself check amperage also. Charging volts and no amps wont work or overcharging. Over charging will ruin a new battery. Also make sure you have clean solid connections between cable ends and battery. Take cables off and clean very good poor contacts will give false readings when checking system.
Jun 27, 2009 | Panasonic LC-X1220P - UPS battery - 1 x...
Need a replacement battery
This is an excellent source for your battery needs.
www.batterymart.com/c-03-6-volt-sealed-lead-acid-batteries.html
Apr 04, 2009 | Vector 2M Pwr Rch Spotlight
Kitchen Appliances - Others Logo
471 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
