Question about Macromedia Captivate for PC
Hi i have problem when i open the captivate its wait a second then it closed other qustion can i open paint program with captivate
2 Suggested Answers
SOURCE: Captivate won't work
hii just change the corrupt file or install a version which is compatible with operating system
Posted on Feb 27, 2007
I have a 2017 Holden Captive LTZ 7 and I am trying to find the paint code sticker. Wher can I find it. I have looke around the door pillars but no paint colour codes. Please advise Thank you
Hi David They normaly have the paint code on one of the stickers or plates. Try under the bonnet on rear fire wall are there any black or silver plates. Also check under the rear floor cover at the rear tailgate.Or in your sevice manual they normaly have a sticker with your vin number etc.paint code should also be there. Good luck.
Aug 26, 2017 | Holden Cars & Trucks
How do I reprogram my compustar remote to my 2003 Pontiac Montana EXT SE?
Hi Melissa
I have this procedure for Pontiac, try it
  • remotes you will be using on the vehicle. Once you program the remote. all previous remotes that were programmed will be erased from memory. The other remotes will not be functional until you program them again.
  • 1. Remove the key from the ignition.
  • 2. Remove the "BCM PRGRM" fuse from the fuse panel. Use the legend on the fuse panel to properly locate the "BCM PRGRM" fuse. Fuse panel is accessed by opening the front passenger door.
  • 3. Close all of the doors.
  • 4. Close the liftgate.
  • 5. Insert the key into the ignition, and turn to the ACC position.
  • 6. Turn the key to OFF and then back to ACC within 1 second.
  • 7. Open and close any vehicle door. A chime will be heard when the system enters into programming mode.
  • 8. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
  • IMPORTANT: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  • 9. Repeat step 8 now for each additional remotes to be programmed including any existing remotes.
  • 10. Remove key from ignition.
  • 11. Install the "BCM PRGRM" fuse back into the fuse panel and test remote(s).
Good Luck
Apr 11, 2014 | Cars & Trucks
How to scan passport photo
How to scan a document or picture using Windows PAINT
Turn your printer/scanner on!
Click START
type PAINT
click PAINT under programs at top
untitled-paint window opens
in top left corner click the little white arrow
click FROM SCANNER OR CAMERA
choose settings you require
click preview (scanner may have to warm up for 20 seconds)
preview appears in window
adjust edges if need be (click/hold/drag)
click SCAN
item appears in Paint
ckick the white arrow again and choose SAVE AS, give it a name and click SAVE (it will automatically save it to PICTURES)
you can now RESIZE or ROTATE the scan
you can also add text to it by clicking the letter A and drawing a box on the scan
If you want to email it, just close Paint, go to PICTURES, right-click on the scan and choose SEND TO then MAIL RECIPIENT
Aug 26, 2011 | HP Officejet 4355 All-In-One InkJet...
I use window vista .....when i install my hp laser jet 101b printer....the last step stopped and told me to plug in the usb caple...and the usb caple is arlready plugged...what can i do
Just unplug it and wait a few seconds and then plug it back in...the computer should then recognize your printer and go from there, giving you direstion on how to proceed..
heatman101
May 09, 2011 | HP LaserJet 1018 Printer
Facebook's main page is not opening ..i dont know y is ths happening.:S...everytime i open it there comes a blank page without any information..:'(...but when i open it frm facebook blog .com thn it opens...
Please try to delete cookies, and use a modern browser like mozilla firefox,
you can delete cookies from Tools -> Options -> Privacy -> click the remove individual cookies link,
Thanks
Aug 11, 2010 | Facebook Social Network
I can't figure out how to scan from the printer and send to the computer to work on document
First, make sure all of the drivers for your printer were downloaded from the CD that came with your printer and make sure your printer is connected to your computer and turned on..
Second, if you are using a Windows PC, Click on:
Start > All programs > Accessories > Paint
Third: When the Paint program opens, in the top toolbar click on, File > From Scanner or Camera > then select your printer by clicking on your printer's icon > then click, OK.
Fourth: Place the document you wish to scan on the glass of the scanner and click on: Scan.
The document will be scanned and automatically sent to the Paint program.
Fifth: Click, File > Save as > (name the document) and save it in your Pictures folder.
You can now close the Paint program and open your Pictures folder. Click on the document you scanned to view it.
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
How do I use the scan option on the C6280 to scan a document on my desktop. I can print to the printer but cannot figure out how to set it up to scan
Mar 29, 2010 | HP Photosmart C6280 Printer
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Help Please
Hi Krumpqu33n,
To make all image formats open with Coral Paint Shop Pro.
1) Open Paint Shop Pro
2) Click the 'File' menu and choose File Associations.
3) New window will open, click 'Select All' button, click Ok
All the best,
Gerry
Jan 31, 2008 | Corel Paint Shop Pro 9
Sep 15, 2006 | Macromedia Captivate for PC
Macromedia Captivate for PC Logo
16 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
