Question about GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop
BOILING WATER SPILLED OVER FROM POT INTO COOKTOP AND NOW IGNITOR KEEPS CLICKING
  • GE Master
  • 2,605 Answers
Hi, water is a great conductor of electricity. It is likely nothing to be concerned about in this case though, if you light the burners and allow the water to burn off/evaporate from the ignitors it should be fine. It happens all the time with gas ranges and cooktops. Once the ignitors are dry they will stop conducting/sparking unwanted. Hope that helps calm your concern. Thanks for coming to "fixya" for your solution. Please take a second after reading this to rate the info provided to you. Good luck. Macmarkus :)
Posted on May 02, 2010
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
Jun 07, 2011 | Maytag Cooktops
We have a GE free-standing range top. I spilled water everywhere when my pot overflowed, and the clicking noise will not stop. All burners burn though, what to do?
This is a very common problem when moisture comes in contact with the ignitor. The ignitor sometimes stays in one position causing the clicking sound. it will eventually wear itself out. Best thing to do is try to take it apart, clean it, dry it and adjust it if necessary. If that doesn't work for you, then the ignitor may have to be replaced. Good luck
Jul 11, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
We are having a dinner party and our 5 burner gas pro series frigidaire stove top is clicking. I tried to turn off and clean the ignitors but nothing seems to work. Please help!!!
you have a stuck ignitor switch. they are mounted just below the knobs. you cant get to them until you remove the unit and then the top.
if you spilled water or something boiled over, it could get into the switches and cause this.
if you reach under the cooktop, in you cabinet, you can just unplug it from the outlet, or try to shut off the breaker to the unit. that will stop the clicking and you can deal with the repairs after your party.
Jan 10, 2010 | Cooktops
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Pot overflowed and then flames from R side and clicking
yes this is commen when you spill liquid on the spark module what happens is it grounds itself out and will continue to spark until it drys out. you should be fine.
Jun 20, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Thermadore Stove Top Ignitors Won't Stop Clicking in the OFF POSITION
Needs to be serviced. The electronics for the igniter section has gone bad.
Sep 03, 2008 | KitchenAid 32 in. KECC502 Electric Cooktop
GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop Logo
941 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
