Question about Acer Aspire 3000 Notebook
No sound coming from the speakers
How do i get my sound back i have already install winxp , still not sound , reinstall the driver still no sound some helo me please
    Scholar:
  • 101 Answers
Have you enabled it in the control panel? Start>Control panel>sounds and audio >change the sound scheme. May be set to no sounds.
There should also be a slider control somewhere on the laptop, make sure that this is turned up.
Posted on Mar 25, 2008
No sound winxp reinstall
You still need to install all the drivers for your computer to make sure that the video, sound, and all other things work perfectly. You can get the drivers from the Drivers and Utilities disc that came with your computer. Make sure that the disc is for windows xp.
Or you can go the computer's manufacturer's website to get the drivers. Download and save them into your computer and extract. After installing all the drivers, I suggest that you install RadarSync to keep all your drivers updated. Keeping them updated all the time can make you avoid from getting any problems.
I hope this helps!
David.
Feb 12, 2013 | HP Pavilion Computers & Internet
How to install sound driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
dont forget to vote
hope this helps
Feb 09, 2011 | Microsoft Windows XP Professional for PC
No audio even i already installed the audio driver
also
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
When i press "matrix" i hear no sound coming out
you might try uninstall both the sound card and its drivers then restart your computer before reinstalling them only do this if your sound card and its drivers have these on a disc
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
Jan 25, 2011 | Logitech X-540 Computer Speakers
MY COMPUTER DOES NOT PRODUCE ANY SOUND.WHY?
Install the Sound Drivers. If u have installed the sound drivers then update the window. If u have already updated the same then your system's speaker have some issue.
Nov 18, 2010 | HP/Compaq P4 System - WinXP Pro/Office...
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Can not hear sound though driver is installed
Make sure that the sound drivers are properly installed. Also test your speakers and make sure that they are working. If required reinstall the sound drivers from the motherboard CD
Nov 25, 2008 | ASUS M2N-MX Motherboard
Audio problem on toshiba satellite m115-s3094
Most likely no. I would check the model of the laptop and go to the company's webpage to download the drivers. If you'll list the model of the computer I'll try and provide you with a link to all applicable drivers that you would need.
Nov 21, 2008 | Toshiba Satellite M115-S3094 Notebook
No sound coming out of the speakers
This sounds like a driver or settings issue. Go into control panel and open up the sound and audio devices control. Go to audio and make sure that the proper sound card is selected for playback and recording. If you don't see your card listed in the drop down menu, try reinstalling drivers for your sound card or Sometime the driver might be for different version of windows. I've seen vista driver install properly in winxp, but no sound. Either that sometime it's the OEM driver provided by the chipset/soundchip manufacturer but differ from the one supply by board. Maybe the board manufacturer implemented a special design, thus the OEM default driver will not work. Other than that, it could also be the version conflict with another driver. Say your sound card driver is the older one, but you've updated your chipset driver to a newer one since your last install. The old sound card driver might not be compatible with the new chipset driver and so on.
Try download a full set of drivers for your system, that way you're sure all your driver is up to date
Jan 26, 2008 | TDV Vison vi06fv19x Monitor
Acer Aspire 3000 Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
