Question about Refrigerators
Freezer is working but refrigerator compartment is warm
  • 1,284 Answers
Hi, Look into back of the freezer and tell me if there is a layer of frost building up. If yes then the defrost heater and defrost thermostat should be changed. You will also need to unplug and remove the rear panel in freezer and use a hair dryer to speed things up. Let me know what you find and I will send you the parts links to you.
Take care
Posted on May 02, 2010
Mod# ABB1922FEW... the freezer works fine but the refrigerator is warm, there is very little food in the freezer.
If the vent from the freezer to the refrigerator is not blocked with food or paper particles, then it's likely the defrost system is not working properly. You will need a technician to determine the cause.
Jan 22, 2013 | Amana AFB2534DE Bottom Freezer French Door...
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
Started icing in freezer compartment so i defosted 4 24hrs. switched back on now freezer not working at all in fact its getting warm in freezer compartment fridge seems ok compressor seems 2 get quite hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 25, 2011 | Microwave Ovens
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Warm refirig compartment
is there a heavy frost build up in the freezer section?? do you hear the fan running?
May 20, 2008 | Kenmore 77870 Top Freezer Refrigerator
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
