Question about Sony KP-53V80 53" Rear Projection Television
Sony kp-53v80 i have a sony kp53v80 i have double vision or red lines on the left side of the screen a repair guy fixed it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and ge moved it back in line and it only took a few seconds to fix how do i get that grid using the remote
Here is a complete solution.
http://www.fixya.com/support/t257424-colors_out_alignment_curved_lines
Posted on Apr 21, 2008
  • Sony Master
  • 8,617 Answers
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Posted on Mar 31, 2008
    Lines across screen & no sound
    KP 53v80 is way too old to be fixing---recycle it as most landfills will not take that as it has toxic Glycol inside of it.
    Apr 29, 2012 | Sony KP-53V80 53" Rear Projection...
    Red lines, blurry picture
    try this link. It fixed my sony.
    www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
    Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
    I have double images in red on my screen any ideas?
    You have a convergence problem, time to call for service.
    it should run about $300
    Jul 12, 2009 | Sony KP-51HW40 51" Rear Projection...
    KP-46WT510 Red lines and double vision
    yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
    Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
    Sony projection tv model kp53v80
    Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
    The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
    You can find more details and solutions here on Fixya at the following link below. Or click HERE
    3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Mar 19, 2009 | Sony KP-53V80 53" Rear Projection...
    Sony 52"
    i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
    Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
    Kp53v80
    yes most likely it shorted out your hori transistor and you may have a bad FBT.flyback transformer.
    Nov 17, 2007 | Sony KP-53V80 53" Rear Projection...
    The color keeps going out
    The repair tech used cheap parts or did not replace both convergence chips.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    2c07611.pngSolution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
    Nov 12, 2007 | Sony KP-53V80 53" Rear Projection...
    Working fine next day red light on solid
    Shorted hori output transistor and bad 1200pf 2k volt capacitor.
    Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
    Sony KP-53V80 53" Rear Projection Television Logo
    547 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
