Question about Car Audio & Video
Hi,I would like to remove my car stereo to enable me to install a Xmas present. The car is a Hyundai Sonata 2005 Model. Thank You Keith
  • 32 Answers
Hi Keith,
"Ric" at Classifieds1000 explains the process better then I can:
http://autoforum.classifieds1000.com/Hyundai-Sonata/2005_Hyundai_Sonata_radio_removal
I would however wrap a flat head screwdriver or stiff/strong butter knife in electrical tape to pry the trim to avoid scratches.
Best of luck!
Posted on May 02, 2010
Po338 2005 hyundai sonata
Trouble Code: P0343
Camshaft Position Sensor High Input
Possible Causes:
CMP (Hall) sensor signal circuit is open or shorted to ground.CMP (Hall) sensor ground circuit is open.CMP (Hall) sensor power circuit is open (check fuse in the I/P).CMP (Hall) sensor is damaged or has failed.PCM has failed.The other code is not listed in this listing.
Dec 22, 2012 | 2005 Hyundai Sonata
DO NOT HAVE RADIO CODE FOR RADIO HYUNDAI SONATA EF 2005
you will have to go to a dealer and prove ownership and the vin# and they will give you the code and reset the stereo
Feb 12, 2010 | 2006 Hyundai Sonata
I need help with a wiring layout for a stereo.
Forget it...go to a car stereo installation shop and buy a wiring harness for your car ($20-40) and you're done!
Good Luck
P.S. might as well buy a dash kit ($30) to make installing the radio simpler as well...if you DON'T have a car stereo shop nearby, order parts from crutchfield.com
Jun 23, 2009 | 2007 Hyundai Sonata Limited Sedan
Radio won't work after battery change in my 2005 Hyundai Sonata. The trunk light is also on on the dash. Thanks!
In the newer vehicles most of the time the stereo has a security code that has to be entered in order for it to work after power has been disconnected. That code should be in your manual. Hope this helps!
Jun 15, 2009 | 2005 Hyundai Sonata
I have a problem where when I depress my brakes on 05 sonata
I might need a brake light bulb. I know it sounds stupid but i had have a few of them that the wrong bulb was put it and it caused the dash lights to turn off and on.
Mar 25, 2009 | 2005 Hyundai Sonata
Stereo codes
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Please note: Not all stereo codes can be calculated from the Serial Number
Feb 16, 2009 | Hyundai Motor 2003 Sonata
Locking gas tank cover - Hyundai Sonata
IT may the fit in the car as the model of the car from 1999-2005 has the same body features ...
Good luck.....
Dec 09, 2008 | 2000 Hyundai Sonata
2000 hyundai sonata windows dont work fuses ok no power to master switch
MY CAR STEREO MY CAR NOT WORKING MY CAR IS HYUNAI SONATA 2000 MODEL
Jul 23, 2008 | 2008 Hyundai Sonata
Installing new steroe
No it is not necessary to remove whole dashboard. AUDIO UNIT 1. Disconnect negative battery terminal. 2. Remove center facia panel.c984350.gif
May 30, 2008 | 1996 Hyundai Sonata
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
