Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My car when i brake there is a noise coming from the drivers side and it sounds like when you open the water tank in the engine and the water glugs to the top
    President:
  • 1,294 Answers
This the time when you should no use your horn.......................
Posted on Mar 25, 2008
Passenger power door noise opening or closing
Can you be more specific? Is it kind of a glug glug or click click but deeper? If so it is doing the same as my 2005, check the upper roller/bearing while opening and closing. I fixed mine by spraying White Lithium grease on the roller/Bearing
Mar 01, 2015 | 2003 Chrysler Town & Country
Leaking gas underneath engine on drivers side
it may be that u are leaking gas from the fuel line. follow it from tank to the engine and look for a leak. do this asap as it is fire hazard
Apr 07, 2014 | 1995 Toyota Corolla
Clicking sound
It sounds like a relay. You need to hunt it down!
Jan 04, 2018 | Mitsubishi Montero Cars & Trucks
When it is brewing it make a loud noise during the brewing
Any coffee brewer will bring water to a boil and expel the hot water over grounds or into a container. This water is sometimes under great steam pressure and is released by the user with a knob, handle, etc. These pressurised machines all make noises but should be within the normal operating range while using the machine. If it makes noise other than when in use then there may be an issue. Have a technician check for safety reasons as you are dealing with a 'steam BOILER' . For drip makers there should be no pressure other than the normal 'glug-glug' sounds while brewing. A commercial brewer will just have water sprinkling down into the basket and possible 'whine' noise as the tank refills. But if it's not your normal noise then have a tech check it out. ukeboy2@yahoo.com
Oct 14, 2013 | Coffee Makers & Espresso Machines
Gas tank has started to make a lot of noise, you
Sounds like the baffles have come loose in the tank. The only thing you can do is replace it.
May 06, 2009 | 2004 Dodge Durango
2004 hyundai accent. trouble filling gas tank
I have a 2005 Hyundai Accent, It is not possible to fill the tank if you are letting the petrol pump run at full speed.Trying to fill up quickly it will only build up pressure and cut off. Next time you fill up just pull the petrol pump handle half way, it will take longer to fill but you wont get the blow back. Modern petrol pumps are getting quicker all the time.Hope this helps you.
Mar 23, 2009 | 2005 Hyundai Accent
Water coming from engine into overflow tank
Sounds like an overheating problem, best to get it checked, maybe thermostat stuck closed, pluged radiator, head gasget, cracked head.
Feb 08, 2009 | 2000 Cadillac DeVille
The fill tube for the fuel tank is either clogged with something or the anti-siphon feature (what stops people from stealing your gas) is fouled up. The tank and fill tube have to be inspected.
Jan 28, 2009 | 2004 Hyundai Santa Fe
Clicking sound coming from the driver's side rear by the tire
We just recently purchased a 2000 Expedition. It is wonderful shape but it has started making a ticking noise from under the hood , when you start it. Can anyone help us?248c23f.jpg
Dec 26, 2008 | 2000 Ford Expedition
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
