Question about Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR)
Usb driver ma , xp sp2,installd,n not detecting usb devices, is not installing usbd.sys file for usb driver
    President:
  • 2,351 Answers
Make sure you're USB is [Enabled] in you're bios.
http://www.intel.com/Products/Desktop/Motherboards/D945GCLF/D945GCLF-overview.htm
Use you're manual as a guide to checking this setting.
Manual link; http://www.intel.com/support/motherboards/desktop/D945GCLF/sb/CS-029157.htm
Cheers'
Mike
Posted on May 03, 2010
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Feb 20, 2009 | Microsoft Windows XP Professional With...
G700 sony ericson - USB connection problem
hi ths is dacs
Try to format your memory card... that is the result of not safly removng ur phone from ur pc.. it usualy afects the memory card...
format the card using ur phone..ok...
Jan 03, 2009 | Sony Ericsson G700 Unlocked GSM Smartphone...
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
Sound driver problem packard bell moudle no.m5xxx
take a driver cd which will came with your system and try to install it agian after then you get it . it means that your sound driver is not installd properly
Jun 06, 2008 | Computers & Internet
Usb not working
hi
if u have xp sp2
then go to device manager in computer properties .
then uninstall usb controller
then restart sys
Mar 25, 2008 | Compaq Presario 5000 PC Desktop
USB
checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Aug 18, 2007 | Microsoft Windows XP Professional With...
Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
