Question about Mach Speed P4M800 (890552603480) Motherboard
VISTA UPGRADE FAILURE
TRYING TO INSTALL VISTA ON MACH SPEED MB P4M800 AND I KEEP ENDING UP WITH MESSAGE "WINDOWS CANNOT CONFIGURE VISTA TO RUN ON THIS COMPUTER. PLEASE ADVISE. THANKS, JIM
    President:
  • 2,351 Answers
Hi ZJIM, download & run windows vista adviser fro microsoft.
This program will check your system & even your printer if its connected & turned on. After its runs the testing it will advise you what will & will not run with vista. It will also show you where to get updates for your system so you can run vista.
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=vista+adviser
Good Luck!
Mike
Posted on Mar 26, 2008
SOURCE:
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
I can't get the front audio jack on my PC to work. I have a MachSpeed p4m800 mobo.
Many times the front jacks are enabled via the software from the company. Look in the SETTINGS - CONTROL PANEL- then a REALTec icon. They make a lot of MB hardware. Not Sounds... In that area you have to tell it to use the front or rear jacks. It can get real complicated this days for something simple like that.
Jul 08, 2009 | Mach Speed P4M800 (890552603480)...
Mercury p4m800 motherboard drivers free download
(1) Manufacturer's Name and Computer Name; (2) Model Name and Number; (3) the ID of *********** board. if you have a problem finding it we can help you. (4) A sequence of events in detail, from a little while before the failure, during failure and after failure. Thank you very much for your consideration and decision to use our service... My name is Constantin (arzconst is my internal nickname with Fixya.com)
Jun 13, 2009 | Mach Speed P4M800 (890552603480)...
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Nov 27, 2008 | Computers & Internet
Motherboard P4M800-M7
Microsoft has a program that will run on your current PC. It will check & confirm if your system can handel Vista. It will also show you what is not compatible with Vista. It will check every piece of hardware including your board & even your printer if it's connected & turned on.
It's a must use program for people who are thinking of installing Vista.
Click the link provided: http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Than click Download Windows Vista Upgrade Advisor
Good luck...
& please vote.... Thanks
Mar 07, 2008 | EliteGroup P4M800-M7 Motherboard
Open Questions:
BULLGUARD cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
Oct 16, 2019 | Best Computers & Internet
VIPRE cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This VIPRE USA phone number is ranked #2 out of 2 because 7,728 VIPRE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the VIPRE USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, VIPRE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. VIPRE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact VIPRE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling VIPRE USA Calling VIPRE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from VIPRE USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with VIPRE USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare VIPRE USA's phone numbers against each other. Contacting VIPRE USA in General While I8OO8O31O69 is VIPRE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach VIPRE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact VIPRE USA.
AVIRA cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This AVIRA USA phone number is ranked #2 out of 2 because 7,728 AVIRA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVIRA USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, AVIRA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVIRA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVIRA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVIRA USA Calling AVIRA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVIRA USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVIRA USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVIRA USA's phone numbers against each other. Contacting AVIRA USA in General While I8OO8O31O69 is AVIRA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVIRA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVIRA USA.
Oct 16, 2019 | Avira Computers & Internet
See all Mach Speed P4M800 (890552603480) Motherboard Questions
Mach Speed P4M800 (890552603480) Motherboard Logo
74 people viewed this question
Top Mach Speed Computers & Internet Experts
Ekse
Thomas F. Schneider
Marvin
Marvin
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
