Question about E-Machines 17F2 17" CRT Monitor
Yellow screen why does my monitor screen sometimes turn yellow?
  • Anonymous Nov 28, 2008
    random change of screen colour to yellow, more frequent on bootup.
  • Anonymous Apr 12, 2009
    my computer screen suddenly turned yellow. plse help
  • 28 Answers
If it is a random ocurring thing, then I would say that it is going bad. However, it is also possible that the video card could be going bad. My bet would be the monitor, however.
Posted on Mar 25, 2008
    New Friend:
Had the same issue. Updated the display adapter driver and it solved the problem. In Windows 7, go to Device Manager - Display Adapters. Double Click on the adapter and go to Driver tab. You will see a button to update driver. After it updates you will need to reboot. Problem solved...
Posted on Jun 12, 2010
Check you video card & monitor cable....some pins may have been defective.
Posted on Jan 22, 2009
SOURCE:
Yellow light
Change the power plu fuse for the second monitor.
Disconnect the data lead from the monitor and reconnect it
Feb 04, 2018 | IBM ThinkVision Computers & Internet
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
Should I replace Monitor?
Your monitor is telling you that it is time for you to replace it. Your monitor is going bad on you and will only get worse.
Mar 26, 2012 | Computers & Internet
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor turns off: Light goes from green to yellow
Check first your signal cable from cpu to monitor, reseat or retighten its nut. Or test it using an spare monitor, if this also happens. If it does not then its practical to have the monitor be replaced.
Other way around like fixing its cable is also a consideration it maybe also a broken connection.
May 25, 2009 | HP Compaq FS7600 17" CRT Monitor
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Open Questions:
See all E-Machines 17F2 17" CRT Monitor Questions
E-Machines 17F2 17" CRT Monitor Logo
988 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
