Question about Cameras
I have a Targus sd/sdhc mmc card reader writer
I have a Targus High Speed sd/sdhc mmc card reader/writer that is not reading my video,s. It reads and downloads the pics fine, but the video's are missing. I double checked to see if they were on my internal but they are not, they are definitely on the memory card, but when I plug in my reader only the pictures show up and NOT the video's.
sainisonu
  • 156 Answers
SOURCE: memory stick / card slot not reading
Right click on my computer,click on properties,Click on Hardware Tab,Click on Device Manager tab.Here u can find ur multimedia reader.If it is disabled it shows red cross on it.Or if it is not installed it shows yellow exclamatory sign on it.
Regards
Sandeep
Posted on Oct 25, 2007
glamaxjoe
  • 56 Answers
SOURCE: Recognizing / Reading SD Card?
Yes...go to the google website or drivers.com to find the driver of your computer and you can type the search box "dowload" your specific brand of you pc..............
Posted on Dec 16, 2007
Felinna
  • 42 Answers
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Posted on Feb 23, 2009
axebro112
  • 56 Answers
SOURCE: Can't copy pics from camera to frame
hmm sounds like the frame doesnt support the HC. what you should do is, transfer from the camera to a PC, then PC to a standard SD card and try.
Posted on Mar 19, 2009
issy2
  • 462 Answers
SOURCE: PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
Posted on Jul 31, 2009
I purchased a card reader and it will not read my s d card. what might be the problem?
maybe the driver isnt installed or the sd card is locked.
it could also be that that type of rreader cant read the format your info is in on the sd
what type are both
Nov 03, 2013 | Philips Targus TGR-MSD500 USB 2.0 Secure...
Tip
You can purchase a Targus card reader from Walmart which will plug into a USB...
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site:
To operate plug card reader into the USB port, go into "My Computer", click "Removeable disk drive", insert your memory card into the card slot and upload your data. Please remove your memory card before disconnecting the card reader.
on Dec 13, 2009 | Saws
Tip
Downloading picuters directly from your digital camera SD or XD card.
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site: To operate plug card reader into
on Dec 04, 2009 | Cameras
Targus High speed SD/SDHC/MMC Micro SD-TF Card reader could read any of the SD/SDHC/MMC cards earlier when I had purchased it on my Lenovo Think Pad laptop having Window-7 . Now it is showing, when in
This is more likely a problem with the card. If the partition tables corrupt then Windows will see the card but won't be able to read data on the card. You will need to format the card.
Jan 30, 2013 | Electronics - Others
My gateway computer won't read my 32gb sdhc card
If your current card reader isn't compatible with SDHC cards then you need to get one that is. While SDHC cards fit into the SD slot, they care electronically incompatible and won't work in devices not designed for them.
Dec 29, 2012 | Cameras
A memory card in a digital camera can be read in the camera but not in the computer
My guess is that you have an SDHC (Secure Digital High Capacity) card in the camera, but the card reader attached to your computer can read only the older SD cards. SD cards that are 4GB and larger are SDHC types, and should have SDHC prominently displayed on the label. The card reader on the other hand, was probably made before the SDHC type cards were ever made.
You can find a new card reader that support the high capacity cards for under $20 in many places. Unfortunately, the older card readers can not be upgraded to read the newer cards - but the SDHC readers can read the older SD types.
Sep 30, 2009 | Kodak EasyShare Z740 Digital Camera
Thankyou
Jul 31, 2009 | Electronics - Others
Driver
Very Simple just go to :
http://www.dxgtechusa.com
Click on "Customer Service"
then Click on "Downloads"
then you will see "Drivers"
Pick the One you need and your done
see very simple and thanks for allowing me to solve your problem
Jul 06, 2009 | DXG Technology DXG-305V Digital Camera
JENSEN VM9512 SD SLOT PROBLEM
I don't have this unit but I have this problem with another unit. Problem when unit read only 1-4GB SD without this symbols HC because this cards which have HC is high speed storage and need high speed storage readers or this unit need new upgrade to read SDHC and I think upgrade is not possible for this unit. You need to use only standard SD 1-4GB cards. Or you can ask service or upgrade is possible.
I hope I help :)
Oct 10, 2008 | Jensen VM9510 Car DVD Player
Reading 4Gb micro card in targus TGR-CRD25 25-in-1 card reader
This is already a really old card reader which is not capable to read HC (High Capacity) memory cards. DO, the 2GB are the largest it can read.
Card readers are inexpensive today, please buy an up to date one which can read SD as well as SDHC and SDXC card types.
See also the same question from year 2007 here:
https://www.dpreview.com/forums/thread/1957326
May 29, 2017 | Electronics - Others
Cameras Logo
1,082 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
