Question about Samsung A177 Cell Phone
What is a sim card reset code
  • 1,428 Answers
A sim card is also referred to as a puk code which enables you to reset your sim card and all related pin codes in case you forget,
The puk is a network associated code and can be gotten from the sim card packet or directly from the network provider.
Cheers
Posted on May 02, 2010
SIM LOCK CODE FOR SAMSUNG GT-E1087T.
The phone is not any network but still there is a sim lock with unknown password and no other sim card can not be used hard reseting codes default password are not working plz help
Nov 19, 2012 | Cell Phones
Poor recepshion on my iphone
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve signal strength issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
May 25, 2010 | Apple iPhone 3G
Show phone restricted in nokia 3110c
WHEN I INSERT SIM CARD IN MY PHONE SHOW THAT PHONE RESTRICTED.NOKIA 3110C
Mar 12, 2009 | Nokia 3110 Cellular Phone
Locked sim card
Hi
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Nov 04, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Puk code for sim
Hi
imei has noting todo with puk code which is on the sim card which is not related to the phone at all.
Sep 28, 2008 | Nokia N95 Cellular Phone
PLEASE HEEEEELLLPP
The default Security code for Nokia is 12345
IMEI: 358672010590572
Master code: 2501005436
Close all applications on your phone. (if you can)
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (anything) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Are you sure it’s the Master code you need. Which is the one that you want?
Jun 23, 2008 | Nokia 3110 Cellular Phone
Security code
SIM pin code:
Master Reset Code
The default security code for Nokia is 12345
Apr 23, 2008 | Nokia 3110 Cellular Phone
Samsung A177 Cell Phone Logo
456 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
