Question about Nintendo DS Lite Console
NDS LITE humming/static sounds
I don't know what to do, It was ok at lunch but when I turned it on, I hear humming sounds in my DS, I thought my earphones was the problem, but when I unplug it, I hear it when I increase the volume when I lower it down It goes away, but the humming sound from loud it softens, but there is still static, is it the cause of moisture, large impact, or foreign objects inside speaker? What should I do, please help! A detailed procedure will really help!!
  • ax_colleen May 24, 2010
    Well it slammed I think because my upper DS screen hedge (I think it's called like that) the left side of the R button (R button is fixed) is broken so the upper DS screen doesn't auto lock, meaning that it is loose, now that I stated this problem, now I'm asking how can I fix this.
    Now that I charged it, it's not making static sounds anymore, but it never stops charging no matter how many hours it takes, and the sounds easily goes out, this problem is done now, I already found out the problem, loose wires, Thank you for asking anyway. I'm closing this problem now.
    Problem Solver:
  • 8 Answers
Did u drop it or let your friend see it? they might had to drop it.
Posted on May 02, 2010
Hi Their is an error that comes on my ds lite it come when i play on the r4 . it says...
What i will do is try and run nds mood, and if not.
OR
Remove the battery cover using a screw driver and hit the reset button.
Mar 03, 2011 | Nintendo DS Lite Console
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
Nintendo ds lite; left and right buttons stopped functioning. Is there a reset for them or a way to correct the problem?
maybe you are playing too hard...i think the rubber inside is damage..try to check it out and replace it if posible..but be sure that the one who will open your nds is a lisence tech. for nds..ok..
Feb 19, 2010 | Nintendo DS Lite
My ds wont charge or turn on
Have you tried a different battery before anything else? Most of the problems I get with these are the battery
May 28, 2009 | Nintendo DS Lite Console
Ds lite not working
i had same problem ( bought a faulty nds off ebay and would charge but nothing when powering up, not even a blink of green light) problem is a component called a L2 its an inductor 33uH in case SMD 1007. its situated dirrectly under the power switch but they are prone to fall off when nds is dropped ect. you need to resolder it on (very tricky). give your nds a shake to see if you can hear it rattelling about. be carefull when opening your nds not to lose the part (its very small, about 4mm long 2mm wide) GOOD LUCK
Jan 05, 2009 | Nintendo DS Lite Console
Ds lite
GO ONTO R4 WEB SITE DOWNLOAD LATEST FIRMWARE PUT ON TO SD CARD,THERE IS SYSTEM,MOONSHL,DS MENU DAT,DS MSHL NDS THEN IT SHOULD BE OK.
Nov 14, 2008 | Nintendo DS Lite Console
I had to format my ds r4 chip memory card and every thing was...
HI REFORMAT THE CARD FAT 32,DOWNLOAD LATEST FIRMWARE ON R4 SITE WHICH IS 1.18 VERSION, THEN PUT ON CARD SYSTEM, MOONSHL,DS MENU DAT,DS MSHL NDS,IT THEN SHOULD BE OK,UNLESS YOU HAVE THE NEW R4 CARD WHICH SUPPORTS SDHC,THEN YOU WANT VERSION 1.19.
Nov 12, 2008 | Nintendo DS Lite Console
Nds lite doesnt power off
Dear Cornjo,
Your situation has baffled me completly. Here are some solutions that might help you:
  • How old is your DS/DS Lite? If it is less than 1 year old or if you have a gurantee for more than 1 year, you can take it back to the shop.
  • Try taking out the battery and not putting it back for at least 24 hours
  • Charge your DS COMPLETLY and do not use it for a while
From Andrei S.
Aug 17, 2008 | Nintendo DS Console
NDS Lite will not turn on
I hear about the ribbon cable not being inserted wel.
Lots of people had it put in place, looking ok but no action from the ds. I suggest to reinsert the ribon cables, i heard its quite tricky with the ds...
Apr 10, 2008 | Nintendo DS Lite Console
R4DS
what is R4DS?
Dec 26, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
159 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
