Question about R.A.M. Computers LASCO-5540 Ceramic Radiator Heater
Having a problem with a heater i bought
I have the longer floor model with digital control and it was working last night but i woke up at like 3 am it was freezing and the heater would not come on just a orange light....its only less than 2 months old
I have the same heater and when that happens just unplug it for about 15 minutes and plug it back in and it should work fine. It only does this for me when I am using a extension cord or a power strip. It needs a dedicated power supply (wall outlet) with nothing else attached. If you must use a extension cord I have found that the heavy gauge orange power cord is the only one that does not overheat and causes the heater to shut off. The heater comes with a 3 year warranty, the longest warranty I have ever seen with a heater.
Posted on Feb 22, 2009
  • pam cote
    pam cote Feb 22, 2016
    i do have it plugged into a power cord, i will see if i can plug into wall. wow appreciate all the help, i will try tonight thank u.
  • 552 Answers
Please check for power to it. Maybe the power cord is broken or it may have overheated and the internal thermal protection keeps it from coming on.
Ceck for any manual resets on or inside the heater.
Unplug the power cord before going inside of it.
Posted on Mar 25, 2008
Goodman Model # GMC070-4b
is the thermostat set for heat and you have power going to the unit correct
Jun 05, 2017 | Goodman GMS90703BXA Heater
KFCS22EVMS leaked once made noise
Watch to see if 1) the water dispenser freezes 2) if you end up with ice build up. What you might have heard was a heater element pop. If that is what happened, then the cooling coils will freeze, no air will flow through the coils, and the freezer will not get very cold. If you can find a diagram of your unit, it may be worth taking a look to determine if the heater element is ok and/or if the cooling coils are packed with ice.
Oct 18, 2012 | Refrigerators
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Last night we woke up to a very full room of heavy plastic smoke, The control panel on our Delonghi heater was burning. The heater was set on 3 and we were only useing The lower setting. Our daughter has...
You are lucky to be writing this, plastic fumes can be poison to humans and animals. It appears you had it in a safe area as the house did not catch on fire. I would not use the other unit but keep it. Contact the manufacturer and see what they have to say. If they want the unit back contact a lawyer before sending back. You may also ask them to cover the cost of cleanup of your home.
Good Luck,
Gil
Feb 28, 2010 | DeLonghi Heating & Cooling
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
1990 thunderbird heater
do you mean the FAN, could be the switch controling the fan. try that first, pulling the fan motor and heater core will be a pain.
Dec 30, 2008 | 1990 Ford Thunderbird
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Oct 16, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
I am soo frustated!!
replace battery. Most digicam last only for about three years working in good condition, after that troubles starts to make your head turns, I suggest not to keep one longer than that period of time. Thats the reason they upgrade models every three to six months!
Sep 07, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
R.A.M. Computers LASCO-5540 Ceramic Radiator Heater Logo
174 people viewed this question
Top R.A.M. Computers Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a R.A.M. Computers Heating and Cooling Expert? Answer questions, earn points and help others
