My pc is telling me my print is pending and its telling me that it is off line. how do you make sure it is on line? also i can see my print server and my hp psc 500 connected to it. help!
Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
The cause :-----A 79 error can be the result of a problem with the network print server that services the printer. To resove the problem:--- When troubleshooting a 79 error, first open the Printer folder from the Start menu on the Print server to make sure there are no jobs pending. A 79 error can also indicate a failure of a printer add-on component, such as an MIO card or a RAM module. All add-ons should be removed and then added back to the printer one by one to determine which module may be at fault.This will help.Good luck.
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes. ? From printers and faxes, you can see your printer icon, right click the printer icon and select online. ? Try to print and that should be working.
Try purging the pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Well this could be a number of issues. First of all try to make sure the printer is on, (yes I know very stupid request but I've seen it happen thousands of times). Then make sure the printer is connected to the PC, either via USB or LPT port or whatever the case maybe. Thirdly, you want to make sure that the printer is installed on the PC. If you goto START/PRINTERS & FAXES, and see if there are any other documents that are stuck or pending, try to delete them out or delete the printer and reinstall it. Then try to print again.
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
