Question about APC Smart-UPS 1000VA UPS System
I WANT TO CONNECT TWO APC UPS 700 VA UNITS TO SINGLE 24 VOLT BATTERY. BY DOING THIS MY INTENTION IS TO CHARGE THER BATTERIES RAPIDLY WHEN THE ELECTRIC SUPPLY IS RESTORED. IS IT POSSIBLE TO CONNECT TWO UPSs IN PARALLEL TO A SINGLE BATTERY
You can't just charge batteries faster by giving them more power. You will likely blow up the batteries as they get hot due to the charging process. I agree completely with 12fixlouie, get a unit with more reserve capacity. You could get a spare set of batteries that you have on a "battery maintainer" (float charger) and then swap the batteries to get more time. Some units even allow this while on battery power (hot swappable). If the batteries could be SAFELY charged any faster be sure APC would have done it to make a better product ($$$).
Posted on May 25, 2010
  • 732 Answers
Waheed70, NO!!!! NO!!! NO!!! DO NOT EVEN THINK OF DOING THAT!!! You may cause catastrophic failure to not one but both APC ups units and will void any warranty you might have!!! If you are in need of longer run time on battery back-up, then start looking into buying an "ONLINE" ups system somewhere in the 5 to 10 kva range. Check out "chloride" systems and "powervar" and "toshiba" and "ONEAC" for info about "true online" battery back-up systems. Bye for now. 12fixlouie
Posted on May 04, 2010
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Ups battery is not charging and having beep sound
Try replacement batteries.
I still not charging, replace the UPS (some chips in charging circuit board is burnt)
Apr 24, 2014 | APC Back-UPS ES 700 - UPS ( external ) -...
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
Hello sir, I don't actually know how to charge my apc cs 650... and And when the power is out, so does my computer.. low battery.. I just need a simple answer about this.. is it not charging? or do i need...
If you connect the control cable to a PC and install the PowerChute Personal Edition V3.0.2 f software you should be able to see if it is charging and what the percentage of charge held in the battery is.
On the CS 650 the lowest power connection is the surge only powerpoint.
To give the battery a full charge or to test it you can connect it to a car battery trickle charger, as it is a 12 volt battery, rthis will at least mean you can check that it holds a charge in the first place.
Dec 23, 2010 | APC APS BackUPS CS 650VA 400W 230V DB9...
We live in an area in south Germany, where sometimes electricity just doesn´t work for only half a minute. Thats why we bought the APC. In the beginning it worked very well, two times it saved our...
if you do not have the manual, clcick here http://www.apc.com/resource/include/techspec_index.cfm?base_sku=BE700-UK
you may need to replace the batteries -- turn the UPS around and take the screws off from the compartment and remoive the battery -- call a battery distributor and ask them to sell you the same type of battery.
if this helped, please reply with a positive repsonse..
Oct 16, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Beeping
These UPS systems do a self check everytime you press the power button. If the voltage in the battery is too low, you'll get a long drawn out beep. A new battery should solve that problem and it is even economical with a unit this size. Here's a link: http://batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Simply remove the single phillips screw on the bottom of the unit and remove the battery cover. Replace battery and that's it. Very simple to do.
Apr 14, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
It is possible to attach the 120 AH battery with APC 1000 va UPS
YES IT IS POSSIBLE TO CONNECT A LARGER BATTER TO THE APC UPS. IT WILL ONLY NEED MORE TIME TO CHARGE THE BATTERY.
Apr 10, 2010 | APC Smart-UPS 1000VA UPS System
My apc ups do not charge batteries it is su 3000 working wel but do not charge batteries
Your battery lifespan is probably over, (3-5 Years) or the battery could have a dead cell in it, my suggestion is to replace the battery. it should be a 12 volt 7 amp hr battery or a 24 volt pack that you will have to get from the manufacturer
Oct 22, 2009 | APC Smart-UPS® UPS System
APC Smart-UPS 1000VA UPS System Logo
330 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
