Model: Celestrial Problem 1 TV will not always switch on with remote or from LHS side of TV when cold. If you persist long enough it switches on. Light on bottom LHS flashes red but will not switch to green(ON) Problem 2 TV will not operate on digital Sound is good, but picture stays blue ie(No Signal) When TV has been on for 10 minutes switching TV OFF then ON again the digital picture returns and TV works normally.
  • 2,335 Answers
Interesting symptoms: possible failing power supply situation.
Please post the model number of your Celestrial TV, & with luck we can source a service manual for you or be more specific with our solutions.
I hope that helps.
Posted on May 02, 2010
I am trying to readdress remote tv2 21.0 IR/UFH PRO but to receiver DISH network VIP 222k. we have tried every way and it always switches remote address tv1. we tried all the steps from the handbook b
Hello, German Quinchia!
I would be happy to provide assistance on this. It sounds like the remote itself may need to be setup correctly. Since this is going to be the second TV, on the bottom of the remote, make sure there is a blue 2 at the bottom instead of a green 1. Once you have the blue 2 showing, try addressing the remote again.
If the problem persists, remove the battery cover. Inside will be a switch. Make sure the switch is toggled to UHF rather than IR. Let me know here if the problem still continues after that.
Tommy Faust
DISH Social Media Representative
Feb 12, 2013 | DISH Network Televison & Video
Zenith 52" plasma tv
Look for any loose contacts in the power outlet. Switch off TV manually at the TV side, switch off power and remove plug. Retry after 48 hours. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Televison & Video
Tv#2 plays the exact same thing as tv#1. remote that goes with tv#2 not working cause remote of tv#1 working both tvs.
dbdandrld,
It sounds like the receiver may be in Single Mode which will make both TV's show the same picture. On the lower right hand side of the receiver will be a mode light. If it is under Single then press the mode button (may be inside a panel) and it should switch to Dual mode. This will allow both TV's to operate independently. Let me know if the problem persists!
Tommy Faust
DISH Network
Sep 24, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
Insignia NS LBD32x-10a blue ray/dvd
Try power-cycling your TV (e.g. turn it off and unplug it for several minutes). If the TV then powers on, reset to factory defaults. If the problem persists, your TV will require repairs. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
May 14, 2010 | Insignia IS-LCDTV32 32 in. Television
Onn tv lost channel list after powercut. no remote control, was using sky remote to control sky and tv, now wont work. cannot make sense of button controls-no manual. 37" lcd.
although initialy I was able to operate tv with sky remote, after power cut none of the codes in my freesat information pack would reconnect to tv. On the forum page one of the emails posted said they had been given the code 0527, it hadn't worked for them but it worked for me. My sky remote now operates tv. It does have an irritating habit of always switching to scart 2 at first instead of scart 1where I have freesat, I then have to use the the remote to switch to scart 1 before I can proceed any further. I am happy enough though, I was pulling my hair out before I found your Website.
Cheers
JP
Jun 17, 2009 | iLO 2600 Television
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
CHANNEL INDICATOR WON'T CLEAR
This is a setting in the menu set-up somewhere or simply press the display button on the remote control unit.
Jan 21, 2008 | Televison & Video
Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA 36" TV Model F36645YX2 - Scrolls Through All Channels
if you have a soldering iron you can try to desolder the program+ and program- tac switches switch on the tv again and see if it still scrolls if it doesnt scroll through the channels it means that one of the switches is faulty your remote should work once you desoldered the tac switches replace the tac switch
Jul 14, 2007 | RCA F36645 TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
