Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
How do you turn off the moen 82691 shower valve when new.
I replaced an old, hard to operate valve.  The new valve is either stuck or I'm not smart enough to figure out how to shut it off..It is off when the knob/handle is centered.  But that doesn't give any adjustment.  At that point shouldn't water be coming out?  Dan
  • 349 Answers
The stem in faucet may be in faucet upside down . you can try taking handle off remove nut that holds stem take it out make sure
you turn water off before doing this.
Posted on May 03, 2010
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Very difficult to pull faucet handle out to turn on in shower installation
the cartridge heeds to be replaced. It sounds like you have a moen shower valve. turning the stem on this cartridge will only reverse hot and cold. it will not fix your problem.
Sep 01, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Replace the cartridge for a moen shower
It is stuck, they come out very hard and a puller is made to make removal easier.
Nov 12, 2009 | Moen & Replacement Cartridge
How do I pull a moen single lever kitchen cartridge out that is old and stuck?I removed the horseshoe shaped clip. When I pull the valve stem, it doesn't budge.
there is a little plastic tool that comes with a new cartridge....you use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
Oct 20, 2009 | Moen & Replacement Cartridge
Replaced moen 2225 cartridge leaks when valve is turned on
Yes you remove the clip by pulling up  on it.  make sure water is off.  then you can replace the cartridge by puling it out.  make sure that you put new cartridge back in the same way you took it out there will be a H and a C on the cartridge.
Jun 01, 2009 | Moen Plumbing
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
222 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
