Question about Microsoft Xbox 360 Console
While playin the xbox kicked me and when i tried to recconect it says my file is corrupt
An update was made while playin a game not sure what it was for and now the memory isnt workin on the stick ?
Assuming you're talking about a usb stick that you were using for memory, try plugging it into your pc and seeing if it's detected. If so, try to reformat it on the xbox to get it working again. You'll lose all your savegame files, but you'll have a working drive again..
Feb 26, 2011 | Microsoft Xbox 360 Console
Failed to write gamer profile settings. ONe possible reason is if you removed your xbox 360 memory unit. Changes to your profile settings might not be saved
hi im a xbox live representative and the solution to this issue is to format the HDD; cause its corrupted, try to check the HDD for corrupted files it indicates that it has a yellow triangle with exclamation point on the middle, if almost all of the files are corrupted and then from there we can verify that the HDD was corrupted. You may also experience slow performance from the console; try mo move the uncorrupted files on a flash drive. Formatting solves this issue. Hope this helps.
Sep 15, 2010 | Microsoft Xbox 360 Console
Gamer tag lost when trying to retrieve it it says not enough memory although there is
check your memory if there is any corrupted files
to check for corrupted files:
1.press the guide button the silver button in the middle of your controller
2.select settings blade and chose system settings
3.select memory
4.check all the folders if there is a corrupted files (corrupted file has a yield sign)
5.delete the corrupted file
then recover your gamertag
Jun 04, 2010 | Microsoft Xbox 360 Console
I have a corrupt file problem I have 2 xbox 360's and one is modded/banned from live and the other I diddnt mod so I can play online. Now I've been playing both for about a year but now I get corrupted...
um dont have the modded xbox hooked to the internet online bro, they see what that one tag does when you go online to gain ur achevements. so my point is to have ur Acheicement points show up on ur gamertag or your profile for instance, it has to be legit, that other xbox must have some file thats not allowing to use it cause that other xbox still has its internet hooked up
i think
Oct 23, 2009 | Microsoft Xbox 360 Console
Playin video file
The possible cause is the files may be corrupt, but if you could play it before then the issue seems to be with the "codecs", install codecs for the same to play videos successfully (Install Klite codec), you can find it here "http://www.filehippo.com/download_klite_codec_pack/".
Jul 03, 2009 | Kensington Electronics - Others
I have a Archos 605 & I have put some music on it. I keep getting messages displayed saying File Corrupted on certain tracks. When I try & delete this track I get the message Error Accessing the...
I`m solved this problem
When playing MP3 press the i simbol on screen
to see info of the MP3 file , if you have file with 48 kHz not sure about bitrate convert this file to 44 kHz
and any bitrate you want and replase old file with new file
Strange this file (48 kHz 320 kb/s) playin whithout any problem when backlight is on
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
Help me please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sounds like an electrical short in xboxs usb port.
check the brick if it has a red light you need a new brick. if not, try unplug the controller from the console and remove the faceplate and try turn it on.
sorry if i cant be more help.
alex
Jul 10, 2008 | Microsoft Xbox 360 Console
Cannot get xbox live on test connection keeps saying fail
un-plug your router from your 360, and unplug everysingle network cable on your entire netowork. Then recconect and try again.
COMMANDO 13295
Jan 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
12 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
