Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My ryobi weedeater will start in the choke or low position but will die when you switch it to the middle or high position.
    Problem Solver:
  • 6 Answers
It's the muffler. Everyone thinks fuel, carburetor, mixture. They're wrong. The muffler is clogged and the unit can't be tuned to high throttle until you clean it.
Steps: Remove the back housing to access the muffler. You may want to remove the gas tank to avoid a spill. Remove the muffler (2 large screws). Remove the muffler door (3 small screws). The screen should be cleaned using a pin (poke out any hardened material). Most important: The muffler door is 2 parts. Pry it apart and scrape off the burnt carbon that is clogging the exhaust path. Re-assemble and start.
Posted on May 03, 2010
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 | Garden
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Pollan weedeater
That unit probably has a high side and a low side screw in the carb. Maybe, the screws are out of adjustment. One should have the letter L along side of it, that's the low side or idle side. The other of course would be the letter H which is the high side. That adjustment is only to be made when the unit is started and idling. When you give it full throttle that's when you adjust the H screw. Factory settings are usually 1 1/4 turns out from dead stop on the L screw and approx 3/4 to 1 turn on the H screw after unit is running. If however, this doesn't solve the problem a simple carb kit can be purchased for about 5 bucks and very easy to install. Good luck.
Aug 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi ss30 weedeater,my weedeater seems to be flooded.need help
Give lots of details when describing the problem. When it started, was the choke on? If the choke is on, try starting it with the choke off, or starting it with the choke on and immediately taking the choke off when it starts, but keeping your fingers on the choke so you can turn it on again if the motor begins to die. As others have described, you have a problem with the mixture screws not being set right or the carb diaphram being damaged. Your owners manual may tell you what settings to start with on the mixture screws, or you may be able to google the model number and get the manual online if you don't have one. At this point you should have taken the carb apart to look for problems and blow out the air and fuel passages. You are making progress. At least you know that it is getting spark, and getting gas. I am not familiar with that model, but many of them have three settings for the choke, fully on, half on, and completely off. If you have that type, after it starts and dies, take out the plug and dry it, then try starting it with the choke half on. You will need to clear out the excess gas while you have the plug out.
Jul 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Jun 22, 2009 | Poulan Garden
I have a Ryobi trimmer and when I start it will not stay on
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Mar 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,098 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
