Question about Nokia 6126 Cellular Phone
Screen Repair Hi there, I need to know how to repair/replace the display screen as mine is damaged please. thanks Idrees
  • Anonymous Apr 06, 2008
    that's a bad answer, bagajguru. I bought a replacement screen off ebay for $40, (better than the $100+ it would take to send it in) and i've been picking and prying at it for the last couple days.
  • 3 Answers
Ok I figured it out.
Here's a quick guide.
-Take out the 2 visible screws beneath the battery cover.
-pry phone apart from between the side buttons and silver.
-There will be a connection port. Free that up and remove the small rubber piece above it.
-Pry off the corner pieces (This was the hardest part)
-Pry apart the the black and silver casing, starting at the end closer to the camera.
-Remove board, unplug the screens and replace.
A tip for putting it back together--I had trouble getting it together so the spring would work. Put it together in the open position.
I did this a week or so ago so I may have missed something
contact me if you need help [email protected]
Posted on Apr 12, 2008
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them replace it for you.
Posted on Mar 28, 2008
SOURCE:
How to repair display screen of n79
Hope your Display ic (Integrated Circuit) corrupt or display is broken so replace it with a new one and see whether it is working or not?
If you can't to it by yourself than please refer to a nearest mobile service centre for repairing.
thanks for using FixYa!
Aug 31, 2012 | Nokia N79 Cellular Phone
My Motorola Droid Screen Went Black because I dropped it and I know it turns on because all the lights come on nd stuff its just the screen is completely black and im not sure what to to do anymore.
i think when you dropped it the mobile display screen is damage or break second your mobile display strip is damage go to repair shop and repair it thanks sushafiq_5.jpg
Jul 01, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Hello, please HELP me!!! SCREEN NOT WORKING
Contact Sony Ericson service for repair and collect the costs from "some1".
Feb 07, 2010 | Sony Ericsson XPERIA X1 Smartphone
Nokia 3110 Classic Cover change
You need another screen to replace this one (has to be identical) first off ,and this repair is something that should be done by a experienced phone tech.
Please Rate This!
Jun 05, 2008 | Nokia 3110 Cellular Phone
How to repair the screen of Advent 7092 Window XP version. Help Please!
This may not be damage, it could be the wrong driver.
Go to the control panel, look at the device menu to see if the display is possibly marked as not working correctly.
Then look at the display settings to see if new driver alternatives have appeared.
Incorrect drivers can damage a display; I've seen it happen (unfortunately).
Mar 27, 2008 | Computers & Internet
Crack screen
HI fllow the step plz. open the uper body > open 4 screew > pick the protection plate > u see a jeck of display > plz open with carefully > place a new display > push the jeck tightly > place the protiton plate > put the screew > tight carefully > place the body. keep voteing THANKS.
Mar 22, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 6820 black screen
you have a damaged screen. they generally go black when they have been cracked and the liquid crystal has leaked. the LCD can be replaced, but if it also has a tired battery, it is probably not worth repair. If you want to replace the display,you need the correct tool to remove the screws from the chassis internally, and the new LCD can be purchased from http://cellink.com.au/products/ They have the tools and parts to repair just about any phone. Good luck. A "fixya" rating for my advice would be great :)
Feb 02, 2008 | Nokia 6820
Screen Is Blank...
Hello Ayoitzpyda, The problem you have is related to the connector from the mainboard to the lcd pannel. It got loose from it's socket and can't send the video signals to the lcd pannel to display. Or it is probably damaged. However in both cases you will need to have it checked at a service center. This shouldn't be an expensive repair but I recomand you to ask them a cost estimate before they actually repair it. If you have a damaged connector that needs to be replaced, it will be easy for them to change it, but if they don't have such spare parts it will be very expensive to get a new one as they are skipped only with the entire screen as a whole part. If you need more informations please post back.
Mar 24, 2007 | T-Mobile Sidekick II
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Mar 08, 2007 | Toshiba 50A60 50" Rear Projection...
Nokia 6126 Cellular Phone Logo
137 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
