Question about DXG Technology DXG-580V High Definition Flash Media Camcorder
Sd card is locked
How do Iunlocked the sd card
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • DXG Technology Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Jan 29, 2011
How can iunlocked my htc cell phone
I accidentally locked my phone while on it now itts saying please enter a new 4 to 8 digit sim pin up above that it says PIN1 code is locked Please enter PUK code I dont remember the code when I set this sim card up can someone PLEASE HELP ME!!!!!!!!!
Feb 03, 2016 | HTC Cell Phones
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
Sir my sd 2gb card was locked i forgett password i want to unlock it help me
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Nov 02, 2010 | SanDisk 2GB microSD Memory Card
My new memory card is say it locked but lock on card is not locked it is a sd 4g
The A410 works with SD cards. Your 4GB card is actually an SDHC card, not an SD card, and will not work in this camera. You have to use SD cards, 2GB and smaller.
Jul 14, 2010 | Canon PowerShot A410 Digital Camera
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Sep 03, 2009 | Canon PowerShot A560 Digital Camera
Sd card
Check if the SD card has the lock tab on, if there is no lock tab on a side, then the card may be defective.
Use an USB card reader to transfer data into computer, then replace the card.
Apr 04, 2009 | HTC Touch Diamond Smartphone
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
DXG Technology DXG-580V High Definition Flash Media Camcorder Logo
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
