Question about Mathematical Technologies Inc. MTI Tristan Soaker Tub
We have a plan for our 24m long driveway. in one section it shows that in 2500 long (2.5m) the gradiant ratio is to be 1:8, the next section 1500 is to be 1:6, 1960mm is 1:4,2500mm is 1:8, 1140mm is 1:40, 4040 is 1:1.85 the rest is flat. How do you calculate the heights?
  • 33 Answers
2.50m @ 1m rise : 08m run
1.50m @ 1m rise : 06m run
1.96m @ 1m rise : 04m run
1.14m @ 1m rise : 40m run
4.04m @ 1m rise : 1.85m run
13.64m flat
Posted on Aug 03, 2010
What is the maximum weight of a travel trailer my 2002 Chevy Tahoe with a 5.3 v8?
two thirds of the weight of the towing vehicle ,so if you look at the paperwork of the car for unladen vehicle weight then two thirds of that ,europeon legislation
Aug 02, 2016 | Cars & Trucks
Lost bothe picture and sound when watching. A bright scene in the show happened and all went dead, thought it was the station so checked others and nothing. Any ideas?
The Audio/Video section seems to have short circuit or if there is overdrive experienced this section would Shut-Off automatically switch-off and Switch-on after a time gap
Jun 26, 2015 | LG 42LE5400 Widescreen 42 Class 42.0...
What is the code 171 mean on my dodge ram 1500
P0171 Chrysler - Fuel System Lean
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 Chrysler Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
P0171 Chrysler Fuel System 1 1 Lean
Sep 04, 2014 | Cars & Trucks
Need a list of rear axles that are compatible with a 2000 Chevy silverado 4x4 1500
FBB}A}}435}937737" checked="checked" type="radio" name="userInterchange" />4x2, 3.08 ratio (opt GU4)
FBB}B}}435}937738" type="radio" name="userInterchange" />4x2, 3.42 ratio (opt GU6)
FBB}C}}435}937739" type="radio" name="userInterchange" />4x2, 3.73 ratio (opt GT4)
FBB}C}}435}937740" type="radio" name="userInterchange" />4x4, 3.73 ratio (opt GT4)
FBB}D}}435}937741" type="radio" name="userInterchange" />4x4, 4.10 ratio (opt GT5)
you know since it's a 4x4 the front and rear axle HAVE to be the same.
Aug 26, 2011 | 2000 Chevrolet Silverado 1500
Dashboard display peugeot 206 hdi 2.0 5 door 2005
Try pushing the bottons at the side of the wiper switch or the light switch. or theres bottons at the display, try them
Sep 05, 2009 | 1991 Peugeot 405
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Rear end gear ratio
you can count the teeth on the ring gear and divide that # by the tooth count on the pinion. An example is: ring gear 100, pinion 10 ...100divided by 10 is 10, expressed as 10 to one. (fake #) your diff is likely a 3 series such as 3.23 to 1. or a four series such as 4.11 to 1. If you have four wheel drive it is critical to match exactly. if not you can get better performance by changing ratio to something that better fits your needs. 4 series pull loads well, 3 series are better on fuel.(depending upon terrain)
Jun 28, 2009 | 2000 Chevrolet Silverado 1500
Mathematical Technologies Inc. MTI Tristan Soaker Tub  Logo
81 people viewed this question
Top Mathematical Technologies Inc. Home Experts
David Jewell
Joseph Prosser
Wayne Tolonen
Are you a Mathematical Technologies Inc. Home Expert? Answer questions, earn points and help others
