Question about Southern Telecom Emerson Bluetooth Headset - Pink Wireless Headset
Why wont my headset pair it keeps saying wrong code
TENGO UN AURICULAR EMERSON BLUETOOTH EM 228 EL CUAL FUNCIONABA BIEN PERO DEPRON TO YA NO SE PUDO CONECTAR Y MARCA ERROR DE CONECCION PONGO MI TELEFONO EN BUSCAR Y NO LO DETECTA QUE PUEDO HACER
Posted on Aug 08, 2010
    President:
  • 1,118 Answers
The passkey for most of the bluetooth headsets manufactured by Emerson is '0000' (four zeros). However, for some models, like the EM250 and EM252, they set it to '1234'.
As you have not specified your headset's model, I hope one of these codes works for you.
Cheers! Carlos
Posted on May 13, 2010
2 Suggested Answers
SOURCE: Can't work out how to pair it with Blackberry Pearl
MAKE SURE WHEN U TURN THE BT250 ON YOU WAIT TIL THE LIGHT IS SOLID NOT FLASHING IT TAKES ABOUT 10 SECONDS IT WONT PAIR UNLESS THE LIGHT IS SOLID.HOPE THIS HELPS!
Posted on Sep 07, 2007
The headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect...
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
Can't pair em227 with my new phone. says: wrong code. but doesn't give me any place to put in 0000. Phone is a Samsung Gusto.
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make the phone's bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros) on your phone. If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards, Carlos
Jan 01, 2011 | Emerson EM227 Bluetooth Headset
My plantronics explorer 230 wont work
i had a similar problem. i think you need to know how to put your headset into pairing mode. thats all. puting your device on with the blue light flashing is different from puting it on pairing mode. i have a plantronics 330. and to put it on pairing mode i had to start with the divice off. then press the button and hold it untill the blue light flashes. then keep holding it until the blue and the red light flashes one after the other. then leave it. at that point the headset is on pairing mode. from there you can find it on your phone. but you're going to need a pass code though.most devices work with 0000 (4 zeros) or 1111 (4 ones). i didnt know mine and it worked with 0000. good luck!
Sep 07, 2009 | Plantronics Explorer 220 Bluetooth Headset...
LG HBM 730 wont take pair code "0000"
I was having problems connecting with my HBM-730 so I got fed up and deleted it from the list of paired devices and set it back up again using passkey 0000. It works fine now.
Hope that helps.
Apr 27, 2009 | LG HBM 730 Bluetooth Headset Wireless...
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Wont hook up to PS3
Alll it says in the manul under Pairing: Charge for 2 hours before use
Step1: When the headset is off, press and hold the mutlifunction button until the headset indicator turns on permantly
Step2: Perfrom device scan from the PS3 in this case.
Step3: Confirm Motorola HS820 in the list discovered by ps3 and confirm.
Step4: When requested to enter Passkey enter:0000
Pairing is successful when the headset indicator flashes rapidly.
Jan 06, 2008 | Motorola Mobility HS820 Consumer Headset
Southern Telecom Emerson Bluetooth Headset - Pink Wireless Headset Logo
221 people viewed this question
Top Southern Telecom Radio Communications Experts
shaun taylor
janman
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
