Question about Acer Aspire 5100 Notebook
Keyboard & touchpad malfunction. action taken replace motherboard & keyboard still no luck.
  • Acer Master
  • 8,404 Answers
Go to the device manager ... delete references to the keyboard and the touch pad ... reboot ...
Posted on May 02, 2010
Hi, my brother has locked the touchpad/mouse part of my mums laptop and I cant find out how to unfreeze/unlock this. It is a packard bell easynote tj61.
there are a few button over the keyboard, one of them is the switch of you touchpad mouse.
If the led of the touchpad mouse button is on, then the touchpad is unlocked.
And viceverse.
Good Luck. Remember to rate my answer.
Feb 16, 2011 | Computers & Internet
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Nov 13, 2010 | Toshiba Satellite A60 Notebook
Out of nowhere my Emachines laptop keyboard has stopped working
Sounds like it's either the motherboard or you may need a new bezel.
Another solution that may be cheaper would be to reinstall the operating system. Or do a factory image recovery and see if it's a software issue. First check the device manager to see if there is an obvious driver issue. If not try reinstalling Windows 7.
If that doesn't work then replace the bezel.
If that doesn't work then replace the motherboard.
Jul 22, 2010 | E-Machines AAFQ50400000K0 Keyboard
Lost my left and right click capabilities
One of two things can be wrong: You may have to remove the keyboard and reseat the little ribbon cable that runs from the touchpad to the motherboard or the touchpad/keys may be bad--which means they must be replaced.
Mar 22, 2010 | Dell F3534 Touchpad
Dell Inspiron 1501 Touchpad locked up
Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
If and external mouse works, the touch pad has failed and a new palmrest is needed.
Jul 29, 2009 | Computers & Internet
Daughter has similiar problem with keyboard on inspiron 1545
Dont just fall for their promises. If your external keyboard works fine, it is surely a manufacturing fault. Insist on a replacement or a service. Tell them your external keyboard works fine and make sure you sound like a techie. People at those companies think we are dummies. Good luck
Jun 24, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Problems with keyboard/touchpad
here what you need to do, disable your keyboard/touchpad because its grounded and soon will not usable anymore... due to this problem, you can use USB keyboard but if you can find the same replacement on it... buy it. Good luck!
Jun 20, 2009 | ASUS Eee PC 900 PC Notebook
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
Inspiron 1520 Can't turnoff touchpad. Unable to connect to Synaptics pointing driver. Find my cursor in random spots all over. Help!! Thanks
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is disabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
If the above does not work, then you might consider carefully opening your laptop and disconnecting the touchpad. Most laptops will run fine without it. However, beware that since all laptops are very different it might even then not be easy or possible to disconnect just the touchpad; it's possible that it's an integral part of the keyboard assembly, which means that you will be practically disconnecting both the touchpad & the keyboard.
If this either did not work, then you might consider replacing your touchpad (and/or) keyboard.
Apr 08, 2009 | Dell F3534 Touchpad
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Acer Aspire 5100 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
