HONEYWELL RTH230B thermostat: we just installed the honeywell rth230b. The fan is working, but it's not turning on the outside unit. We pressed down on the thermostat slightly and it triggered the outside unit on for a split second, but it wouldn't stay on. After reading one of your forums, we disabled the blue wire, and made sure red, green, and white were in correctly. (we don't have yellow). Any ideas? The fan and vents are blowing cool air, but the house is 83 degrees and climbing (because the outside unit is not working). Thanks.
    Genius:
  • 1,416 Answers
what you have to do now from here is that check the capacitor if the maize i.e (wire)_ that pass current over to the compressor is well fix
because this well the unit get is own supply to the over load then the relay section will set out the cooling freely to circulate
please note those wire that you have work on make sure that they are well fix on the capacitor
make sure that there is no lick-age of gas in any form
what i'm saying here this that you need to connect your compressor over to capacitor it is from this section the relay unit will carry out it own function
Thank you and thanks for using fixya.
Posted on May 02, 2010
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
