Question about Nikon Speedlight SB-600 TTL Flash
I have sb600 attached to the d90 and an error of r10 or r30 show up
  • 172 Answers
Reset to factory default,then check again
Posted on May 02, 2010
Sb600 keeps flashing
The the signal to the camera to shoot flash off the camera
change your settings
Jul 11, 2013 | Nikon Speedlight SB-600 TTL Flash
D90 dropped and caused a seal crack at front cover (cracked above lens mount). Build-in flash does not popup. It works well without flash. Do I have to replace the front cover? What should I do with...
The SB600 isn't made any more. I would recommend the SB700. Before you buy an external flash however, make sure that the hot shoe on you camera is still fully functional. An external flash is superior to the pop-up flash under almost any circumstances. Where your pop-up flash limits your shooting distance substantially, I have take pictures at night using an SB700 almost 100 feet from the subject and gotten correct exposure with my D90. Now there is one thing you will not be able to do without the pop-up flash, but I suspect it will never matter to you. You will not be able to use the pop-up flash to trigger the SB700 off camera.
Jun 14, 2011 | Nikon D90 Digital Camera with 18-200mm...
My NIkon SB600 is stuck on my hotshoe-I can not remove it fromt the camera (d80) help
I had a similar problem with my SB25 when I tried to use it on a D90. I took the camera into the Nikon USA Repair Depot in Los Angeles where they took it into the back shop and removed it while I waited without charge. If the SB600 is like my SB700 and SB900's, there is a spring loaded dimple in the camera's hot shoe that clicks into a hole in the SB flash hot shoe. I think if you can slide a thin piece of metal such as a machinists shim, you may be able to depress the dimple and release the SB600. Let me know if it works.
Mar 15, 2011 | Nikon Sb600 Sb-600
My SB600 is on, shows "ready" but won't fire... the STBY shows on even when not connected to the camera. Will not fire. Any ideas?
Aug 17, 2010 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
During using D90 for son's b-day my camera kept freezing up and giving a code of r05 and another code once that I don't remember. Why and what does r05 mean? I even turned the camera off at times but it...
The r05 is not an error. It's simply telling you that the buffer has room for five more pics. It's only a problem when it gets to 0 and stays there.
As to the other error, I'm afraid I can't help you there.
Jul 10, 2009 | Nikon D90 Digital Camera with 18-105mm...
Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Jun 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Toshiba GSC-R30 error code
I had the same problem the 003 error I formatted and reset it, then I turned the camera off and beat the top (where the little speaker is) with the palm of my hand. Turned it back on and the error was gone. May be the lense or hd gets jarred or something.Hope this helps
Jun 29, 2008 | Toshiba GSC-R30 Camcorder
Nikon Speedlight SB-600 TTL Flash Logo
385 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
