Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
I have a hoover windtunnel model U8130-900. The brushes don't turn!
  • 8,404 Answers
My windtunnel brushes only turn with the handle down ... is yours the same? Check the belts
Posted on May 02, 2010
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
I have a hoover windtunnel v2 the brushes underneath wont turn ? its suppose to be beltless what do i do to fix this
Are you sure it is beltless? What model do you have? Looking at another manual there may be a seperate on off switch for the brushes but would need to know your model to be sure.
Dec 30, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6434-900 WindTunnel Bagged Supreme
R U SURE THAT IT IS NOT JUST A SAFETY CUT OUT SWITCH , SOME MODELS HAVE A BLACK BUTTON BEHIND THE BRUSH HEAD DIFFICULT TO SEE SOMETIMES
Aug 17, 2008 | Hoover S3639 WindTunnel Bagged Canister...
I purchased a hoover windtunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=724091
Generic problem for all Vacuums
I purchased a Hoover WindTunnel
Posted by billmar082 on Jun 30, 2008
I purchased a Hoover WindTunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the particles but the filter will not turn. I also haven't been able to use the pet brush for some time. The cleaner has not been used hard about once a week since it was purchased. I am not happy that this product has stopped working efficiently since purchased 6 months ago. Thank you Marcia Long Pottstown Pa
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I sorry you are having a problem with the Hoover WindTunnel Vacuum Model #U8361-900 but I never heard of a filter that you say is self cleaning and NOT turning. I have never seen a filter that turns inside the chamber, the dust and dirt basically go around and circulate around the filter and you can clean the filter by either brushing it off, vacuuming it off or using some type of brush to clean off the filter such as and old paint brush or if you have some type of blower system – that would work as well. You said your vacuum is less than one year old so I would contact your local factory authorized Hoover dealer in your area or to cal the cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
