Question about Alpine Blackbird II PMD-B200 GPS Receiver
Screen stuck on blue Alpine start-up screen when I turn it on
Can my alpine 9883 change colors?
The screen stays white but there is a way to change button color blue/red can't remember exactly I think it is in the func/setup button
Mar 22, 2010 | Alpine CDA-9883 CD Player
TME-M780 Alpine 7inch screen turns on but no p
Did you resolve the problem? I ha e the same!
Jan 10, 2010 | Alpine Car Audio & Video
Blue screen with alpine DVE-5207
there is a ground wire off of the back of the deck find it using intall manual the screen is blue because this wire isnt hooked up and set properly this is a safety switch so the driver cant operate the vehicle and try to watch a movie at the same time
Jan 26, 2009 | Car Audio & Video
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
My Alpine CDA-7863 does not read when I turn the ignition on,the screen does not read,it just make a clicking noise.I have no idea how to manually wire it .I just bought a 1996 tahoe and this Alpine was in...
1. you can go here and get a wiring manual with right model #.
http://www.alpine-usa.com/US-en/support/
2. The red wire goes to ignition switch/key.
Yellow wire goes to constant hot/battery.
Black wire is ground.
Blue wire is for power antana you do not need to hook that to anything.
You can look at this diagram for a little more help it is not your radio though but it will give you a reference point to look at. All radio red,yellow,blue,black wires are the same on all radios.
http://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
go to page 42 on this site for wire diagram.
Good luck with problem.
Dec 15, 2008 | Car Audio & Video
Alpine CDE-9880R INTERRUPT MESSAGE ON SCREEN
Yes after speaking to a alpine tech at their support centre it was due to on of the cables on the back of the stereo which is used to detect a blue tooth device was touching a earth connection so has to insulate the cable now all working ok.
Nov 07, 2008 | Alpine Car Audio & Video
Motorized Screen gets stuck sometimes - Any fix for it?
Mine does this too, it need a new gear for the actual flip out, if you send it to Alpine they will fix it for around 25 to 30$$.
Sep 27, 2006 | Alpine IVA C801 Car Video Player
Alpine Blackbird II PMD-B200 GPS Receiver Logo
111 people viewed this question
Top Alpine GPS Experts
Oloyede Monsuru
Are you an Alpine GPS Expert? Answer questions, earn points and help others
