Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
My story is the same. I have an MM600, replaced switch, and still trips breaker in variety of configurations. I have tried both of the relevant configs recommended on this site, and no luck. Is there another place that could be causing the trip at the breaker?
  • 3,740 Answers
As you know a breaker tripping is a result of a direct short inside the electrical circuity of your mower.
That short can be anywhere from just beyond the switch all the was down to the winding in the motor.
There are 2 switches Item 3 and Item 7 of this link:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/MM600_TYPE_1
Places for a short are the power wire from the switch to the motor connection. (Item 28 of link)
A broken motor brush where the carbon brush has broken off and the metal from the spring is now touching wither the motor chassis or across multiple segments of the armature.
Check items 46, 47, 48, 48 this link for damage:
Also check Item 80 Brush of the above link (picture below link
http://www.toolpartsdirect.com/cgi-bin/parttools.cgi/242273-00
A bearing in the motor can have failed allowing the armature Item 65 of link to drag on the stator item 70 of link and cause a stator short where the armature damaged the stator winding.
The above items are all things that can cause your problem. It will take a multi-meter and some resistance checks of the circuit to isolate exactly where the short is.
I would connect the meter across the 2 power cord terminals i.e unplugged and simulate mower use then start disconnecting wires one at a time working my way backward from the motor to see when the short disappeared. If the short is in the motor... then we are back to all of the times above except the cord and switches. The all have to be isolated and checked out.
Kelly
Posted on May 02, 2010
    Scholar:
  • 47 Answers
Just a though to entertain too - Though Kel seems super correct in his thinking!
Have you unplugged the extension cord and tried it in a different socket on a completely different circuit? Face it, it's warm out there now, electrical load from a previously idle A/C system or something could be forcing your breaker to trip on whichever side of the house you're plugging your mower into. :D
Posted on May 09, 2010
How to reset electric box after vacuum cleaner blew power out
One of your circuit breakers is tripped internally and didn't trip the handle. You'll need a voltmeter to find the defective breaker and replace it.
Aug 22, 2014 | Electrical Supplies
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
R1874t trips breaker
See my help file on door switches here.
The relevant service manuals are here and here.
If needed, you can order Sharp parts from Encompass here.
Apr 13, 2013 | Sharp R-1874 Convection/Microwave Oven
15 amp cutler hammer branch feeder type AFCI triped off and will not turn back on. I have tried switching off for 10sec and then back on and still nothing. Also, the test button will not do anything. The...
if the breaker has tripped the test button won't do anything ,, for the breaker to trip something down stream of it is causing this to happen,, check all the switches and or receptacles in the circuit that are controlled by this breaker, 3 types of line problems cause tripping,, ground to line, Line to line, and line to neutral. in this ,, also consider that extension cords, faulty appliances , ( lamps, radios, anything plugged in with a feedback short ) will cause the breaker to trip. even a nail to hang a picture that pierced the wire can cause this, add to that , a AFCI breaker will trip much more easily than one thats not, or even a GFI breaker, , try this, if you have the knowledge to do electrical work in a panel, if not get someone who is, switch the tripping breaker with another one of the same value, ( in this case 15 amp) see if the one you put in place of the one thats giving you problems trips. If it doesn't, you have a weak or bad breaker, so just replace that one, if it does, your going to have to trace out that entire circuit to find the reason for the feed back into the panel
Oct 07, 2011 | Electrical Supplies
Dryer is tripping all electric in the garage everytime it is put on any ideas why? (looked at plug, checked wiring, changed fuse, emptied water and fluff filter)
First of all, if your dryer is tripping ALL the electric in the garage, you may be overloading the circuit capacity of the garage service. A major appliance such as a dryer should have its own dedicated circuit. That is, a circuit that ONLY the dryer is connected to with a separate service breaker. You may not have a problem with the appliance at all. It may be just be a matter of overloading. You should have a 220 VAC circuit breaker rated at a minimum of 30 amps for an ELECTRIC dryer. Or, a 120VAC circuit breaker rated at 15 to 20 amps for a GAS dryer.
You may also want to check to make sure you have the appliance wired correctly. If this is an ELECTRIC dryer, the following link explains how the appliance needs to wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have a GAS dryer, it should use a 110-120VAC configuration using either 14 gauge wiring for a 15 amp breaker and 12 gauge wiring for a 20amp. The power cord should be of the three-prong variety (HOT, NEUTRAL and GROUND). The color code for the wiring is as follows:
BLACK - HOT (110-120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND (Usually wired to a terminal lug at the terminal block on the appliance)
If you're dryer is already configured with a dedicated circuit breaker, please post back with a MODEL NUMBER and WHICH fuse you are referring to that is blowing. I hope this information is helpful.
Apr 25, 2011 | Dryers
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
I have a nutone 8 amp lo hi off switch keeps tripping breaker and eventually arced at switch . replaced switch and looked for an open or short at connections were I could access . found nothing .tried new...
Sounds like the load is shorted. You don't say what the switch is controlling. What happens if you jump out the switch and just connect the load, then turn on the breaker? If the breaker trips, it's the load itself that's shorted.
May 08, 2017 | Broan-NuTone FAN CONTROL SWITCH
Switch stuck in trip mode
The reason why the breaker stays tripped is a result of a direct short. Unplug every electrical device plugged into an outlet in both rooms and try the breaker. If it stays on, individually start plugging in each device until the breaker trips, that is the defective device. If the breaker stays tripped, start checking wall outlets for short circuits with an ohm meter. If you did not find a short, check your hard wired lamps and appliances for shorts. If you did not find any shorts the only other problem is a shorted pair of wires in the wall or ceiling. You will need to disconnect any hard wired lamps and appliances and check for shorts between individual pairs of hot (black) and neutral (white) then hot and ground. I have a short circuit finder, but you do not need one because the technology is not perfect and you may have to manually check for shorts with a meter anyway which never lies.
Jun 25, 2010 | Square D Co. HOM130 Circuit Breaker
I have a top load Kenmore Elite Washing machine that runs for 5 seconds then stops for several minutes. This pattern repeats. It just started yesterday. What is wrong with it? I have unplugged and...
Sounds like the timer is faulty. Or you lid switch is out of wack. Try leaving leaving lid open and placing a screwdriver in switch located where the lid clip comes down into washer. If this works the switch will need replaced. Timer is another story as you will have to remove top panel and replace timer if the lid switch is not the cause
Mar 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
MM600 - New Switch - Trips Breaker
Wiring Instructions recommended here:
https://www.fixya.com/secure/support/t2575192-in_replacing_push_button_switch
http://www.fixya.com/support/t383610-wiring_diagram_black_decker_electric
http://www.fixya.com/support/t2997089-black_decker_19in_electric_mower
Sep 22, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
871 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
