Question about Honeywell Programmable Thermostat Heater
We installed the honeywell rth230b. The fan is working, but it's not turning on the outside unit We disabled the blue wire, and red, green, and white are in - we don't have yellow. Sometimes when we push down on the thermostat the outside unit starts up for a split second, then dies. And it only starts for that split second if you have the fan in Manual, not Auto.?? :-)
    Novelist:
  • 135 Answers
The terminals on the stat are:
G is fan
W is heat
Y is A/C
C is 24 volt common
R is 24 volt hot-if there is a Rc and Rh terminal, male sure that the jumper is in place and hook the red wire to either screw.
It sound to me that someone was using the blue wire as a yellow. to double check open up the fiurnace or air handle and see what the blue wire is connected to, if it is connected to the yellow, then hook the blue wire to the Y terminal at the thermostat.
If this has been helpful, please rate me and contact me back if you have any more questions,
Sincerely,
Paul Gibson
Posted on May 03, 2010
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
I have a four wire system one is white red blue and green and i just bought the rth230b where do i put them at exactly
Red: Power (24 Vac) Green: Fan White: Heat Blue: Common
Now I would check those at the furnace BEFORE you hook the wires up.
Nov 21, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Sep 18, 2009 | Heating & Cooling
Need help with wiring thermostat
first do you have a heat pump unit or standard a/c? standard a/c connections at the thermostat go like this red wire to rh-rc which is the 24v power and you don't have to remove the jumper.white goes to w which is the heating wire yellow goes to y which is the cooling wire green goes to g which is the fan wire and blue goes to c which is the common wire. so if your stat has rc- rh ywgc you should be set if the wires on the furnace correspond with the same alpha designation.orange may be used if u have a heat pump unit otherwise it may just be a spare you cap off and leave behind the subplate.
May 31, 2009 | Honeywell Heating & Cooling
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
233 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
