Question about Nokia 2600
Not charging - Nokia 2600
    President:
  • 1,561 Answers
Have you try to use another charger to charge it to see if it will charge, because it could be that your charger is bad, if you have and it did not charge, no problem.
It means the charging port of your phone is bad that is why your phone is not charging.
All you need to do is to change the charging port of your phone, changing the charging port of your phone will make your phone charge because the one there at the moment is bad.
Change the charging port and you will see that your phone will charge.
Take care.
Posted on May 02, 2010
SOURCE:
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Can the screen be replaced on a fitbit charge hr
  1. Cached
  1. Cached
  1. Cached
  1. Cached
  1. Cached
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
What is this vendosupport.com?? Why is money transacted to this site without my knowledge??
mony tarnsactions with out my knowledge in vendosupport.com i went to cansel the taransaction
May 04, 2011 | Computers & Internet
Does not charge
Have you use another similar charger to charge the phone to see if it will charge? If you have and yet the phone did not charge, the problem could be from the phone charging port, you will need to replace the phone charging port befoire the phone can charge.
If the charging port i replace, the phone will charge.
Take care.
Aug 25, 2010 | Nokia N900 Smartphone
Not charging
Have try to use another similar charger to charge it to see if it will charge? If you have and yet it did not charge, it means the charger is not the problem.
The problem is the the charging port, the charging port of your phone is bad that is why it is not charging, all you need do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port and you will see that the phone will charge.
Take care.
May 20, 2010 | Nokia 1209 Cell Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Jul 15, 2007 | Sony Ericsson K610i Cellular Phone
Nokia 2600 Logo
237 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
