Question about Traxxas E-maxx Evx-2 Monster Truck
E maxx no reverse movment
I have a e maxx and the evx shows a red light at stop and a green light forword but a flashing green light in revers with no movment please help
  • 748 Answers
Hi
The ESC has the ability to have reverse locked out. This is necessary because race tracks require it. Go to the Traxxas web site and download the manual. Reprogram as necessary. Good luck
Posted on May 05, 2010
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
97 tracker drive fine forword but i have to rev it uo to 3000 rpm befor revers gear grabs?
try changing filter in transmission. sounds like filter may be stopped up.
Nov 10, 2013 | 1997 Geo Tracker 2 Door
Traxxas tq controller has steering reversed. Left goes righ and vice versa
Towards the bottom of the controller there should be two small switches. One switch will be for the steering servo and one for the esc. Channel 1 should be for the steering servo, move that switch and that should correct your problem.
Aug 14, 2010 | Traxxas E-maxx Evx-2 Monster Truck
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
TraxxasE Maxx how do you rebuld Slip clutch looks easy .Do you replace pads or replace hole thing ? Ican see how to ajust the clutch when your done but how do you know when it right ? do you ajust tell the...
for a slipper clutch you replace the pads
for motors clutch you replace the pads and springs
and for the brake you replace the pads unless disc is no longer smooth/pads missing then replace disc too
slipper clutch adjustment, hold the vehicle stationary and turn the spur gear by hand, it should turn if not then loosen nut on slipper, if too easy then tighten...............drive to fine tune......it should slip if stopped at full throttle to prevent spur/clutch gear damage
Jul 18, 2009 | Traxxas E-maxx Evx-2 Monster Truck
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
E maxx steering is too tight
You may have something too tight on your steering linkages, or you may just want to upgrade to a better servo. My Revo's servos are all metal gear and I have never had a problem with them. Receiver batteries on my truck were weak and the tires were hard to turn as well, so check your batteries
Apr 28, 2009 | Traxxas E-maxx Evx-2 Monster Truck
Traxxas E-maxx Evx-2 Monster Truck Logo
276 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
