Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic Projection HDTV
I have a panasonic 47" HDTV model PT-47WX53. When I try to turn it on it does not go on and the LED diagnostic light on the front panel blinks three times. The service manual I have says that indicates a problem in the convergence circuit. Can you offer any professonal advice as to how to fix this problem? Thank you, Johnny
  • Anonymous Apr 03, 2008
    Benimur and Terryfic,
    I really appreciate your guidance. I have removed the circuit board,purchased a new soldering iron(for printed circuits) and now I realize I need to desolder the old joints.I checked for the hitachi kit you recommended online and found it at www.partstore.com I am now purchasing a desoldering pump. With a steady hand and patience I should be able to complete this repair. I will keep you posted.
    Johnny
  • Anonymous May 21, 2008
    Terryfic and Benimur,
    I desoldered the old convergence circuits and installed the new ones, assembled the peices and fired up the TV. Everything works fine. You guys rock. The advice was dead-on Balls accurate. Much oblidged.
    Oddjohnny
    Problem Solver:
I have the same tv and had the sme problem i bought the convergences and my husband (trying to save money) tried to do it himself. He did an awful job and nothing happened. Someone told him he will have to buy a new board. What kind of board? And do u know where we can buy one?
Thanks
Posted on Jun 23, 2008
    Genius:
  • 1,694 Answers
Replace both convergence IC's with up-grade,durable STK394-160E.....use Hitachi kit # X480293 ( has two IC's with some
resistors for Hitachi / Philips chassis ) The price is lower if you buy the kit,rather than two individual IC's.....................T.
Posted on Mar 28, 2008
  • Vista Electronics Apr 03, 2008
    Use the kit IC's only.......disregard instructions concerning
    replacement of resistors..................T.
    Brigadier General:
  • 6,966 Answers
Hi odd johnny,
My sincerest apologies. My area of experience with Panasonic models are rather limited to diagnosis and power supplies. May I recommend instead hdtv_guru, techman or terryfic who I consider more knowledgeable and experienced on convergence circuits.
Nonetheless, I appreciate you bringing your concern to my attention and wish I could do more.
I have taken the liberty of pre-informing these gentlemen of your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
SOURCE:
Panasonic PT-47WX53 HD Projection TV will not turn on
the power light should blink a series of blinks which indicates which circuit has the issue. Respond to this same post with the number of blinks and I will assist with the issue.
Oct 30, 2011 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt47wx52 will not power on
i have a panasonic pt47wx52 hdtv projection monitor . It will not power on and the red led light flases 3 times pause 3 times. What is my problem.
Feb 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53, Would replacing the convergence ICs STK392-110 incorrectly make it so that the tv would not turn on at all and not give a blink code?
If the pins were bridged with solder it could blow the main fuse. I would check the fuse since a panasonic will always light the led if the fuse inst blown, another possibility would be the wires not seated properly especially the bridge connectors bewteen the boards.
Dec 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53 47 in. Rear Projection HDTV Television
replace the DG board which is the small board which plugs into the A Board ( on the left side looking in rear of the set) The DG is the board which lays flat on top of the A board. You can get the A board and the DG board combined at www.tvrepairworld.com They may sell it seperately if you inquire.
Dec 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
525 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
