Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
Posted on May 03, 2010
  • efdepew Jan 04, 2015
    Can a ring get into the pump area of the machine or under the agitator?
Tip
Washer Repair Boise - Whirlpool Cabrio Pump
I've replace many pumps on the whirlpool Cabrio and most of these washer pump failures could have been prevented by removing coins from pockets. Many times coins will make there way to the outer tub and get sucked right into the pump to create a rattling sound. That rattling sound you hear is the impeller spinning against the coin. Since the impeller is plastic, it doesn't take long for the impeller to wear down. Just a tip, please remove coins from pockets. You'll save money and time :->.
A tip from Western Appliance Repair
Washer Repair Boise
on Oct 12, 2010 | Washing Machines
The machiane is making grinding noise
does the sound happen when its agitating or spinning? or when its draining? if its when it spins or agitates it can be the hub number 8 & 9 in the diagram. if its when its draining it the drain pump which is known for coins getting stuck inside it. to check the pump lean the machine back and you will see the drain pump which is the one with the drain hose connected to it. if this helps please dont forget to rate me.. thanks http://lookup.bellparts.com/diagramenlarge/whirlpool/45568/00079213
Jun 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My whirlpool cabrio top loading washer with corner dispensers had some coins trapped in the bottom of the basket. I can hear the coins and some water. When the washer goes into spin it apparently throws...
    You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
    Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My cabrio washer sounds like it has coins under the basket when it goes through the spin cycle. how do i get them out?
    Assuming that this is a Whirlpool Cabrio, see the following Whirlpool Service manual. It has sections on how to pull the agitators, tub etc.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
    May 11, 2010 | Kenmore 22422 Top Load Washer
    Washer doesn't drain just buzzes
    Most likely you have a coin stuck in the drain pump. Mine did the same thing, and we removed the drain pump, then removed the coin and it began working again. Just be sure to check all pockets for coins as this is a big problem with the Cabrio washers.
    Oct 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Two dollar coin fell into a space between agitator and a drum.
    you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
    Nov 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    2,719 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
