Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Barely printing at all
Say's error code3501
  • 64 Answers
So guess what, I bet you installed you cartridges when you purchased the printer. The meaning to your error is: "Printer access door has been opened".
How else would you have got the cartridges in. I would recommend not looking at the test pages from printers as they show all error conditions the printer has ever has and never really show the ones that mean anything...
Posted on May 07, 2010
Print job barely visible
Have you tried configuring the settings? I had that problem with an Epson Stylus NX125. I put in all new cartridges, went to properties and tried all options. setting it to black & white, then to color and the greytone. Printing samples after each change. I finally came up with an acceptable print after moving it back to color.
Mar 14, 2013 | HP Officejet Pro 8500 All-in-one -...
Hp CP1215 print barely visible
Check in the printer 'preferences' and see if it is set to 'draft' printing.
also check the -Advanced- tab for a possible -Toner Save Mode- option.
Tallon41
Sep 08, 2012 | HP Office Equipment & Supplies
When I initiate a print job on my HP P3005 laser printer it makes a roaring sound and then I get a error 52. I have read its the fuser and then I read its the laser scanner. Which one is it? Tom
Error 50.x related to fuser &52 for laser scanner assm.
For tec guys only: Open laser scanner assembly, remove laser scanner motor rotor, lubricate the shaft fix it back. (dont do this job with bare hands) check best of luck
Sep 21, 2011 | HP LaserJet P3005 Printer
Color printing, not so colorful. Even with new cartridges
Your model has some print quality pages built in to help diagnose and solve print problems.
1) Press <Menu>
2) Press <Down> button to highlight "Diagnostics"
3) Press the <checkmark>
4) Press <Down> button to highlight "PQ Troubleshooting"
5) Press <checkmark> to print the pages
If you see print-quality defects on the print-quality-troubleshooting pages, calibrate the printer. To calibrate the printer (optimize print quality):
1) Press <Menu>
2) Press <Down> button to highlight "Configure Device"
3) Press <checkmark>
4) Press <Down> button to highlight "Print Quality"
6) Press <Down> to highlight "Full Calibrate Now"
7) Press <Checkmark>
I hope this helps!
Dec 21, 2009 | HP LaserJet CP3505dn Printer
Kodak easyshare printer 5300 error code3501
3501 error code indicates that the printer access door is open(The door that you open to able to see the ink cartridges).
If you recieved this error code and yet printer access door is open try to reopen it and close it, then unplug the power cable of your printer for 10sec then Plug the power cable back.
You cannot do any task on your printer if you have this message 3501. if this isue not solve call kodak tech support toll free 1 800 421 6699
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error message is causing me fits - won't print
Make sure the top cover is closed as well, Brother has a one year warranty, so it can be repaired at no charge
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Printer not printing at all
Though there was no message to indicate toner issues, I changed the cartridge anyway. That must have been the problem. It works now. The old cartridge was 3 years old and, though barely used, may have outlived its quality. Thanks for writing back.
Aug 11, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Jul 05, 2008 | SATO CL408e Thermal Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
48 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
