Question about Troy Bilt Tb70ss Gas Trimmer
Brand new gas weed eater runs for awhile and then stalls out. now, the starter cord will not even pull out at all?!?!
    Sergeant:
    Champion:
  • 333 Answers
If it's brand new take it back
Posted on May 02, 2010
Weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How to replace the pull cord on model featherlite 71188
how to remove and replace the starter pull cord on a palen100 , 16''
Jun 11, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The pull cord to crank up the weed eater is not pulling out.
You can try replacing the cord with new,failing that if the cord is sticking on starting,and releasing the cord,you will need a new starter clutch,you should check with your servicing agent first before commencing work,as sometimes these are not worth repairing,rgds
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
325 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
