Question about JVC AV-32720 32" TV
Video just reduced to a tiny horizontal line across the screen. sound is fine, what could be the problem? jvc tv model av-32720
  • JVC Master
  • 1,229 Answers
You have a bad vertical IC at its worse or one that may need resoldered. Be sure to check the grounds on this IC and check for rings around the pins. And you can bet in the immediate area you have bad capacitors that created a hot vertical IC. This will cause the Vertical IC to break down!
Posted on May 02, 2010
Black screen horizontal white line
vertical scanning circuit is Defective.this is not hard to repair.contact service technician
Jun 15, 2011 | JVC AV-32720 32" TV
Tv has power, can hear sound, but picture is black. when i shut it off a horizontal white line appears for a short second. can this be easily fixed?
Well, If you are technically sound, you can fixed it, but I will like you to check the line Or Fly-back Transformer and the horizontal and vertical side of the circuit very well.
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
Bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | JVC Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Lost Picture
try tapping tv on side with palm and see if it works it might be a bad video chip
Oct 19, 2008 | JVC AV-32432 32" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Televison & Video Logo
105 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
