Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Hi my toshiba tv is jumping and flickering i have trouble seeing the menu to a point were i can not see them if possible do u know how this can be fixed
    Problem Solver:
  • 17 Answers
To things it could be connection problems in your cables, or your color wheel inside the set is in need of replacing.
Posted on May 04, 2010
My Toshiba I don't have a remote my TV and it stock on channels 3,4,5 My model is 27a45 I got a Toshiba remote but it not working at all I don't know what to do
I do not know your TV type but there may be a few answers.
You say that you have a Toshiba remote but its not working?
Is this the correct one for this model?
Or has it laid around near the TV because it did not work and left?
I say this because a faulty remote with batteries in is very bad if a set can "see it" because it may send pulses out which a TV may act upon without you being aware, I would remove batteries from a remote in a faulty condition for this and other reasons.
Having said this my thoughts for your problem may be its been set into Favourites mode which a person has selected certain channels to be more easily selected.
Another old system I am aware of was during channel setting would be to engage Skip Mode for certain channels to "leave them out" (to stop certain ones being viewed by children).
A further problem might be that your set has developed a fault which will require possibly an engineer to look at.
Cures for it :- well the first two would possibly require a working remote and instruction book to check out the above points I mentioned, as for the last this may require you to Reset you TV back to an original state again, this will reset its software and possibly cure it. This would be found in Menu-Setup area of its menu.
Hope this gives you some help.........
Nov 07, 2016 | Toshiba Televison & Video
My toshiba 50 inch plasma tv model 50hp66 powers on but has no sound or picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 18, 2015 | Toshiba 50HP66 50 in. Plasma Television
My TV (Toshiba or Samsung or something like that) a flat screen will uncontrollably go down in volume and if I take the batteries out of the remote it still adjusts it's own volume down. I've tried th
Well the difference between a Samsung and Toshiba are pretty extensive, so without knowing what TV and what model, we cant help very thoroughly. Have you checked with the manufacturer directly? it sounds like the TV is quite new.
Oct 08, 2014 | Toshiba Televison & Video
Model LG 42 PX3RVA ZC Hi I have a lg plasma, bought in 2005 new. I know it's old.. But was working well until a couple of weeks ago. Picture would flicker initially when turned on, then as tv "warmed...
With no stand by light, you are not getting power.Unplug TV and check fuse on power supply. You will need a meter to look for shorted components and possibly leaky/bulged capacitors that are killing your power supply. flickering could be part of the bad power supply or possibly a problem with YSustain area of your TV
Feb 15, 2014 | LG Televison & Video
I have a Toshiba CF27H50 that just stated losing the picture after about an hour of viewing. After an hour, it starts to flicker and then the picture just is lost and it just goes to black/snow screen and...
This is a common symptom of tuner trouble. A common problem is bad solder connections inside. As the set warms up, small cracks on joints from the tuner circuit board to its metal case can cause the trouble you describe. If you tap on the TV or wiggle the connector where the antenna or cable line goes, the picture will sometimes pop back in if this is the case. It's also possible the tuner has parts that quit working as they warm up. The only way to know for sure is to remove the tuner, check over the connections, repair any that are iffy, and see if the trouble continues. This is not a repair for a do-it-yourselfer, though, because of the soldering involved.
If the trouble isn't bad connections in the tuner, there's not much you can do. I've checked the parts sources I use. The original Toshiba part is no longer available and I haven't found any replacement. If you're using a cable box or other video source, you can keep using the TV just for its AV inputs and not worry about the tuner any more. Otherwise, given repair labor cost and lack of parts, it's probably more economical to replace this TV instead of trying to repair it.
Jul 22, 2011 | Toshiba CF27H50 TV
Hi i have a 42" LG lcd tv .When i switch it on
the inverter for the backlight likely has a bad capacitor or more. The fluctuating high voltage is causing the jumping and eventual blackness until sufficient charge is on the caps, at which point it stabilizes...it eventually will stay black unless the caps are replaced.
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote...
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Jun 02, 2010 | Toshiba 32AV600E 32 in. TV
When turned on, the screen has waves in it across the top and flickers. It is unreadable. When the TV warms up it seems to be better but is starting to flicker or flash all the time now.
Your Toshiba TV has hyperboard inside and there are few electrolytic capacitors (may be 10) that need to be replaced.
If you are comfortable with soldering parts in PCB then go ahead or ask help to any friend that knows electronics stuff repair.
Let me know further query.
Thanks.
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
