Question about Singer Quantum XL-1000 Computerized Sewing Machine
My Singer Quantum XL 1000 should be able to handle free motion sewing. I use the Darning/Embroidery foot, drop the feed dog and start to sew. Well, sort of. Within 4 or 5 stitches the thread will break or the needle will break. I have tried using various threads both in the needle & bobbin without success.
  • taadam May 02, 2010
    Thanks for the suggestions. I have previously tried all of them. Have also recently had my machine serviced so it is in perfect condition. I sew & machine embroider daily with no problems. But I just cannot figure out how to do free motion sewing.
Taadam -
I also have the Singer Quantum XL-1000 and recently wanted to figure out how to free motion quilt with it. I was having the same problem you were - the top thread kept breaking after a few seconds. A google search brought up this webpage, and like you, I didn't find help from the other solutions for our particular machine.
But I just figured it out today, and thought I would share! Turns out, on the Singer Quantum XL-1000, the stitch length MUST be set to something OTHER THAN ZERO. I know this is totally counter-intuitive. All the tutorials I found online about free motion quilting say how important it is to set the stitch length to zero. I'm guessing that maybe it's because the XL-1000 is computerized, and essentially too smart for that - that setting the stitch length to zero signaled to the machine NOT to give any thread, thus the breakage.
But try setting your stitch length to somewhere between 2.5 and 3.5. I've been quilting this afternoon with Sulky thread (I'd been using Coats and Clark before, and found that even with the proper settings, it makes a big difference to have a higher quality thread) and the stitch length set to 3.0, and it's going great! I'm also using a 90/14 needle, because that's what the instruction manual recommended for free motion embroidery.
Hope this helps! Happy sewing!
Posted on Jul 11, 2010
    Brigadier General:
  • 3,513 Answers
Is the presser foot lowered? Make sure the presser foot screw that holds it in place is securely tightened. Before lowering the foot, bring the thread tails under the foot and to the back or side of the machine.
If top thread breaks try rethreading the machine, adjust the tension and check the needle. Are the top and bottom threads compatible? Another possible cause is a burr on the needle plate. This can happen after a needle has been deflected off the plate and broken while stitching. To remove the burr, use an emery cloth (not sand paper) to gently file the rough spot.
If bottom thread breaks - Clean the bobbin case and rethread the bobbin.
If needle breaks - Check to be sure the needle is inserted correctly and the needle clamp is screwed on tight. Check the top tension and needle size. A too fine needle for your fabric will cause the needle to break. Are you pulling or pushing the fabric through the machine as it is stitching with your hands, causing strain on the needle? Let the machine's feed dogs do the work.
Giving you a link so that you can have a vivid idea of the root cause of your problem and the solutions to that.
http://sewandserge.com/tshoot.asp
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on May 02, 2010
  • 713 Answers
Hi,i think the problem is as a result of the fact that the needle was not installed in the right position,but nevertheless,this solution will be helpful to you;
STEP 1 Open the bobbin cover and remove the bobbin from your machine. Examine the bobbin case and make sure there aren't stray threads jammed into any grooves. If you see clumps or strands of thread, remove them with your fingers or with tweezers.
STEP 2 Look over how the bobbin is positioned in the case and whether or not it is inserted correctly. Different machines hold the bobbin in different ways and some machines don't use a bobbin case. Consult your machine's manual for the proper way for its bobbin to be inserted.
STEP 3 Make sure the thread is wound evenly on the bobbin. If your thread has large sections of loose loops sticking out from the rest of the thread, they easily could be causing the problem. Rewind the bobbin, if needed.
STEP 4 Clean the shuttle mechanism and the bobbin case with a small soft brush, such as a make-up brush, and a dust cloth. Remove as much dust and tiny fiber pieces as possible. Resist the urge to blow into the machine to clear away dust, this can send debris farther back into the machine, causing more serious problems.
STEP 5 Oil the movable pieces of the shuttle by putting a few drops of sewing machine oil on a Q-tip and rubbing the Q-tip over the hinge-like turning areas. Do not add too much oil to the machine; one drop goes a long way.
STEP 6 Reload your bobbin into the machine and sew a line along a piece of scrap fabric. Check your thread tension and adjust it as needed following the manufacturer's instructions. The upper thread should never show through the bottom and the bobbin thread should never show through the top.
Thanks and good luck
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Feb 09, 2018 | Husqvarna Sewing Machines
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
Would it be possible to do free motion sewing on my Singer Mon Ami II deluxe 390 machine? I don't have any sort of darning foot and the feed dogs can't drop.
You probably could but would need to address the darning foot and feed dog issues.
If you search, you may be able to find a darning foot for your machine or some sort of adapter. A darning foot is necessary because it is shorter in height which allows the fabric to be manipulated by hand. A regular presser foot presses the fabric against the feed dogs and needleplate which mechanically manipulates the fabric.
A lot of machines whose feed dogs do not drop came with a feed dog cover. Yours may or may not have. However, you may check into a Supreme Slider which is a slick sheet that covers the feed dogs and provides only a small hole for the needle. A lot of quilters love this sheet because it provides a slick surface that makes fabric manipulation easier.
Supreme Slider These are available in multiple sizes and from various vendors.
Sep 27, 2016 | Singer Sewing Machines
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Jun 20, 2015 | PfaFF Creative 7570
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
I'm looking for a darning foot to use on my Quantum CXL so I can do free motion quilting. Is there one available?
You will have to remove the adapter for the clip on presser feet to use the darning foot - http://www.sewingmachinesplus.com/pd60-4021.php same as you would to use the walking foot.
Apr 02, 2010 | Singer Quantum XL-1000 Computerized Sewing...
Singer Quantum XL-1000 Computerized Sewing Machine Logo
391 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
