Lg burner refuse to burn .wav format
I have .wav files on my computer and it always in 44 octet
    Scholar:
  • 47 Answers
  1. try playing the *.wav files on your computer from their location on the hard drive
  2. Make sure that your writer can burn all the other file formats by burning a disk e.g data disk, if it fails then its not a problem with wav files its the writer that require reconfiguration
  3. If it can burn the disk then burn a music audio disk with your *.wav files (music audio cd uses *.wav format)
Posted on Mar 25, 2008
SOURCE:
What is an old format for burning cd off pc that will play on this CD player
WAV files, if you burn WAV format, they normally work, that gives you about 80 minutes but you can (on some pc's using NERO or the Amiga) write an 'overburn' CD up to 100 minutes, but that's not guaranteed to always work, i stick to a 93 minute limit & it works fine. WAV cd's are also called an ISO CD by some programs.
Apr 22, 2017 | Computers & Internet
Tip
How to convert M4P music to MP3
The music and audiobook files you purchased from online stores are protected by DRM. But most mobile players doesn't support DRM format. However you can burn the protected music files to CD-R/RW disc to make an audio CD, then use CD ripper softwares to rip the audio cd track back to MP3, WAV, WMA etc.
There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.Following the steps , then get your job one easily.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. Go to http://www.noteburner.com to download the program. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:Documents and SettingsAdministratorMy DocumentsMy MusiciTunesiTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Oct 28, 2010 | Computers & Internet
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
I can not burn a cd with GH24NS70 cd/dvd drive . No software with the drive. Can you e-mail me the software for this drive. Thanks....
there are plenty of free burning software programs on the internet
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). [email protected] ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
Sep 06, 2011 | LG ELECTRO LG DVDRW GH24NS70 24X SATA with...
I cant burn my music onto CDs and my computer tells me i dont have a cd burning software when i should have one
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8
BurnAware Free is a full-fledged disc burning tool - fast, lightweight, feature-packed and, most importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray discs containing data, digital photos, music and video. With BurnAware Free, you will be able to create bootable or multi session CDs and DVDs, high-quality audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files, burn disc images, copy discs to backup ISO images and do a whole lot more.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files; new option for setting the number of copies you want to burn (available for all disc formats); discs can now be verified immediately without being ejected first (if the drive supports this feature); numerous other small improvements that make the program easier to use and more effective; burn files and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC, WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD, Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc images; burn speed and other options can all be set automatically.
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
Macrium Reflect Free Edition. An award winning disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect supports backup to local, network and USB drives as well as burning to all DVD formats. This version is for non-commercial home use.
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for performing a different task: Read - read a disc to an image file; Build - creates an image file from files on your computer or network (you also can write the files directly to a disc); Write - write an image file to a disc; Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare it against a given image file to ensure the actual data is correct); and Discovery - used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing.
Apr 19, 2011 | HP Computers & Internet
Can't get Backpack to let me convert to audio .WAV files.
http://www.ashampoo.com
if you download the free version of ashampoo burning studio9 it will burn cd's in the "au" audio format that cd's use. You must also make sure the car stereo will actually play a cdr disc, as some don't.
Apr 11, 2010 | Micro Solutions Backpack CD-RW/DVD-ROM...
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Burning cd's
Sure you can.
But when you download music, it will be in a compressed Format. Usually MP3 Or WMA.
To enable it to work Correctly In Any Logical CD Drive Or Player.
You Have To Convert The Downloaded Music Files To The WAV File Format. Otherwise the music will only be recognised on A PC Or MP3 Or MP4 Player.
Mike @ compurepair.
May 10, 2008 | Computers & Internet
I cannot produce a finalized music cd able to be hear on regular cd player
the .wav file has to be converted to .mp3 or .cda prior to burning in order to hear it in a regular cd player. Those applications have the ability to turn .mp3, and .wma to .cda format, which is what normal cd players read but they lack the ability to convert .wav to .cda
Mar 01, 2008 | TDK DED+840 DVD±RW Burner
Burns cds
This could be several issues.
Firstly there could be a format compatability error.
if the burner is looking for Wavs and finding MP3s, then you,ll need to convert the formats, for compatability.
Secondly this could be a copyright protection function, if the cd your trying to copy is protected, then the writer will refuse to copy the files. ( can Sometimes happen if downloaded )
I,d suggest locating some better Software, for your writer.
Or re-installing your original packet-writing software that came with the writer.
Hope this points you in the right direction.
Mike @ compurepair.
Jan 24, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
168 people viewed this question
Ekse
Alun Cox
