Question about HP LaserJet 1100 Printer
Black strip over all printed papers
I have been using my hp laserjet 1100 a long time ago
everything was o k but recently i noticed something strange :
every printed paper has a vertical black strip two inches wide and at a distance about two inches away from the right edge of the paper.
I have tried to clean the toner cartridge but the problem still exists.
Do you have any suggestions to solve this problem?
thank you very much.
  • larainemarsh Mar 26, 2008
    My HP laserjet 1200 series printer/copier has a vertical black line running down the middle of the page. What can I do to fix this?
    Scholar:
  • 141 Answers
Check your Drum cartridge, if you see your strip replace it....If it's not the problem you may have a bad Fuser ....
Posted on Mar 25, 2008
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
My hp laserjet 1100 doesnt respond when i try to print
Not sure if this will help but if you right click on the printer and go to properties ( when your in printers and faxes ) and go to the ports tab I think it is and un tick the check box that says bi directional support and try it again.
Also what error are you getting thats printed off ?
what lights are on the printer and where are you getting the driver from, if the disc then try the latest driver from the hp website
Apr 22, 2009 | HP LaserJet 1100 Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
My HP Laserjet 1100
tray to clean the leans reflectors
Mar 12, 2008 | HP LaserJet 1100 Printer
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1100 not printing
Firstly PRESS THE BIG BUTTON
Secondly if this doesn't work remove toner cartridge and look inside there maybe a piece of paper in there.
Thirdly Remove paper look down the paper feed entrance check there is no paper there.
Finally Replace toner cartridge.
Hope this is of help and please rate me
Cheers J
Dec 29, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
230 people viewed this question
Ben Johnson
