Question about Blackburn Flea Front HL Bicycle Headlight and Flea Rear Flasher Taillight C
The front light turns off after a few minutes
It may be in demo mode. Hold the power button for 20 seconds.
Posted on Sep 04, 2010
Front end unlocks after a few minutes
If the light turned off you most likely have an electrical problem. your front hubs are vacuum controlled. when you put the car in 4wd it trips a switch in the transfer case and powers up the vac solenoid which engauges the hubs. You could have a bad switch or a corroded wire
Apr 10, 2014 | 1999 Kia Sportage
Sony 42we655 turns off by then back on after a few minutes
It could be a sign the lamp is nearing the end of its 2000 hour life--another indication is when it turns off do you get blinking lights on front of set or not?
May 29, 2012 | Sony KDF-42WE655 Television
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
Headlights go off after a few minutes of driving.New switch installed.The hi-beam switch will hold the brights on if I hold the switch back.Brake lights work. After I stop and turn off motor, wait a few...
Brake light are on a different circuit with the dash panel and parking lights. There often is a resetable temperature breaker in the light switch. This protects against high current. Are the bulbs standard? Was the car ever hit in the front? Can you try unplugging one lamp at a time and see if one is causing the over current? If the light switch is on the steering column lever then it's probably controlling a relay. The problem could be in the relay.
Feb 05, 2010 | 2004 Ford Crown Victoria
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
TV turns off after a few minutes.
eso es mala configuracin de su tv revise el manual de usuario
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Dryer starts to work and then stops working after a few minutes
doesn't usually happen so quick but may be a blockage in the air duct. take top off. if i remember right, duct runs across the back to the dryer fan. check for lint build-up. if poor air flow, an overheat stat will cut off the dryer
Apr 02, 2007 | Indesit WA 125 Front Load Washer
Blackburn Flea Front HL Bicycle Headlight and Flea Rear Flasher Taillight C Logo
544 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
