Question about Brinkmann Charmglow 810-7400-S Propane Grill
The burners do not get a full flame anyomre, nor
The burners do not get a full flame anymore, and takes for ever to cook. The back mounted rotissere burner doesn't work either. I cleaned the burner holes, but can't seem to pinpoint the problem. The grill is a Charmglow 8905.
  • Anonymous Mar 30, 2014
    when we turn the rotissereon flames come out the back pipe, should there be some thing between the pipi and the hole other side to the elements
  • 8,404 Answers
You may have spider web in the burner ... disassemble and blow it out with canned air or a air compressor ...
Posted on May 02, 2010
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
New smeg gas cook top. flames burn with yellow top
There has to be a small screw close to where the burners are located and all you need to do is turn clockwise half a turn at a time (have the flame/burner on), to adjust the flame . Good luck
Nov 03, 2013 | Kenmore 63942 Dryer
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Gas oven
The symptoms you describe point to a cracked or blown out burner. If you can see the flame on the burner the flames should be blue and even in size.
Nov 15, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Left hand oven not getting hot!!
some older ovens did use one side just as a "bread warmer"...only way to tell for sure is to check if there is a burner below the left side
Jun 02, 2007 | Rangemaster 110 (Gas) Kitchen Range
Brinkmann Charmglow 810-7400-S  Propane Grill Logo
258 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
